Old 11-14-2017, 07:35 AM   #1
Default 1/10 buggy wheels
Does anyone know which 12mm 1/10 4wd buggy wheels have the widest offset?? Looking to make my buggy as wide as I can.. I'd prefer to start with a wide offset wheel and use hexes to adjust from there. My buggy is a '16 XB4
92Mracing is offline   Reply With Quote
Old 11-14-2017, 07:53 AM   #2
snwchris's Avatar
Lets start by, what buggy do you have?? that will help others give helpful information.
snwchris is offline   Reply With Quote
Old 11-14-2017, 08:08 AM   #3
Default Updated
Updated, thank you
Old 11-14-2017, 09:57 AM   #4
snwchris's Avatar
Ahh XB4 same as what I have, best bet is to use the 22-4 Front and Rear wheels.
First page of the XB4 thread has the wheels and hexes listed, also the XB4 thread will be helpful if you have more XB4 questions since others can help answer as well.
from first page:
Most who have gone to the 12mm hexes are using the +0.75mm (#365355) on the front and +1.5mm (#365356) on the rear using standard 12mm rear wheels and TLR 22-4 front wheels which have the same offset as the Xray 12mm front wheels (#369912). Car becomes very stable with this combination.
Also you really don't want to go any wider in the hexes listed, cause you'll run out of thread engagement for the wheel and nut especially with front wheel.
Old 11-14-2017, 09:58 AM   #5
snwchris's Avatar
Also you really don't want to go any wider in the hexes listed, cause you'll run out of thread engagement for the wheel and nut.
Old 11-14-2017, 03:28 PM   #6
Default Yup
Yup, exactly... that's why I'm looking for the widest offset wheels I can find...
Old 11-14-2017, 08:14 PM   #7
ta_man's Avatar
Trader Rating: 151 (100%+)
CRT.5 wheels. They have 12MM hex. The have a 3/16" hole for the axle so you might have to drill out the axle hole a little bit.
ta_man is offline   Reply With Quote
Old 11-15-2017, 01:43 PM   #8
Default I will check these out.
de buggy wheels sgtlt Electric Off-Road 9 07-14-2012 05:52 PM
JAMMIN CRT.5 TIRE LOTS -- 1/10 Buggy and Truck Tires nougat R/C Items: For Sale/Trade 19 09-27-2009 07:59 PM
