Crawler/Basher
#16
Go with a wraith. Reliable. Endless parts support. Build it on A budget or build it to drive through a brick wall. Great crawler. Looks good too! Otherwise, the summit, despite being a good bit outside of the context of the discussion might be worth a look. Fun on the trails and great basher. Keep it brushed and just run it. Fyi known a wraith, scx10, emaxx,summit, scte, rc8.2e, b5m. Summit happens to be my go to all around followed by my wraith.
#18
#19
I own two Wraiths and a Baja Rey, I've owned a Twin Hammers and a Yeti, and I've driven a SCX10 a few times. If you want something that can climb over rocks occasionally, but is mostly good for bashing...get a Summit. The remote-lockable diffs and two-speed gearbox make an enormous difference, because you can reconfigure the truck on-the-fly as you need.
The Wraith is a great truck, but in stock configuration it will traction-roll very easily, and if you unlock the diffs you will lose the ability to crawl worth a damn. The same is true of the SCX10. The Yeti has an odd weight-balance and you have to slow down a lot for sharp turns. The same is true of the Twin Hammers, it's just smaller. I haven't driven the Bomber personally, but it shares enough features with the Wraith and Yeti that I can imagine how it handles -- very good on rough terrain, but not at all optimized for general off-road use. The Baja Rey is MUCH better than the Yeti for high-speed bashing on all surfaces, but forget about crawling with it, the suspension is not designed for it.
When it comes to versatility, nothing beats the Summit -- the Arrma Nero Big Rock might be comparable, but it's a new model and doesn't have the Summit's track record yet. If you can't stand the Summit's wide stance, you can fit it with narrower A-arms from the Slayer and run Yeti XL tires to narrow it up significantly. The only must-have drivetrain upgrades for it are steel center driveshafts and a Leading Edge Machining aluminum shift puck for the transmission; in two years of ownership I've broken a single plastic axle, which cost $4 to replace. Some people say the diffs are weak, but they're not; if you keep the plastic axles as a predictable breakage point and keep the motor close to stock (it can pop wheelies with the stock motor anyway), you won't break the diffs.
#21
The Summit is a good idea though. I haven't had the chance to drive one of those, but they've always looked cool to me.
I wonder if he had the RTR. The shocks in the kit are much higher quality than the RTR shocks.
#22
Interesting about the Bomber. Other people I know say it will out-crawl the Wraith any day but handles speed terribly. Strange how people can have such different experiences with the same vehicle.
I know the Summit doesn't have the "badass" factor of a solid-axle truck, but its competence on pretty much all terrain (when the gearbox and diffs are properly configured) is hard to exaggerate. The only thing it truly lacks is top speed, but I'm currently running mine with 17/65 gearing instead of the stock 14/68 gearing, and the stock motor still isn't overheating. 25mph is good for pretty much anything except speed runs and crazy jumps.
#23
I had the same assumption that the Bomber would be similar to a Wraith. It's not. The Bomber handles much better and will actually stay on its wheels at speed. I hate my Wraith. I love my Bomber.
He aalso removed the spare tire which definitely helped.
