scx10 2
It's a bit of a let down for me.
Stupidly large and heavy transmission and transfer out of the yeti mounted further back and higher than ever before is some sort of joke.
The new axles look alright, with smaller helical cut gears and high pinion. Shame it doesn't use ar60 style splined chubs for adjustable caster.
Cms is pretty meh, it's detrimental for performance so no good for c2, and even the shortest wheelbase is considered a bit long for c1.
On the plus, all metal links and cv's stock is great for newbies that want to just buy it and drive.
Um apparently you didn't even look at their website to see that the axles are splined to adjust caster in 10 degree increments. cms is used for a more scale look like a real truck would have. The transmission isn't out of the yeti as the scx10 and yeti use different transmissions. Also if you aren't happy with the new truck it is backwards compatible with the scx10 1 and you can build it however you want. I'm not a newbie to rc I like to upgrade most of my vehicles but scalers I like to run stock until something breaks.
I think the worst thing about it is the hCG and the added weight in that area. But other than that I'm looking forward to it. But will it be an RTR or will they offer a kit version?
It's a kit. There are plenty of them out in the wild now.
Can you explain your reasoning more precisely?
The axles are totally different.
The transmission/transfer case is totally different.
The chassis is totally different.
battery tray is totally different.
Or do you simply mean the fact that they both come with a chassis mounted servo standard and have a large boxy body with fully width front and rear bumpers?
