axial dingo drive line problem.
Hey guys. I just finished building my scx10 dingo kit. I took it out to the crawler track today to test it and when I would get hung up it sounded like gears stripping. I don't know if the slipper clutch is tight enough or not. I am running a rc4wd boost 35t motor. With stock pinion and trans. And axle gearing. Am I even running the right gear setup. Thanks sean
Make sure you have your drive shafts aligned correctly. If they aren't they'll make a clicking sound when rotating. There are a lot of videos on it. Also, if you can post a video of your problem, it could help us help you.
So your motor was just revving but the gears weren't turning? Or the trans was spinning but driveshafts were not? If the later, could definitely be the slipper. If your motor is spinning but nothing is turning, your pinion is probably loose on the shaft.
