weighting. tires
The Wraith does need some weight down low. Wheel weight is one way. forget the bb thing. Go to the auto parts store and get some stick on wheel weights. Strips in 1/4 oz increments are perfect for 2.2 wheels. Stick them on the inside then mount tire.
Better to have a more balanced rotating mass in a truck that has some speed to it.
another option depending on your rims, nuts bolts and washers
apparently I can't post images/urls yet lol
Usually people prefer to add more weight to the front wheels also. Just something so consider
Stick on wheel weights go as followed..
Non Beadlock, cut glue on back of tire and add 2 and a 12 sticks of lead with sticky back....
Beadlock Non aluminum 2 1/2 sticks.
Aluminum... 2 1/2 sticks...
this goes for crawler or scaler...
Trust me... You'l pull lines like a champ..!!!
Use this. Will be more dense around your rim than stick on weights.
http://www.boaterbarn.com/bullet_wei...94431_prd1.htm
Buy a few pounds because shipping is around 10 bucks
