My tlt axle scaler mock-up.
Well i recently received some tlt axles in a trade along with a tuber chassis and a while load of other parts. The have aluminum lockouts in the rear, and aluminum knuckles in the front. I'm used to axial axles so its definitely something new. Right now i have it just mocked up with random links and stuff i had laying around. I still need to get hardware for it also, the links and stuff are held in place with ziptires and random screws just to check geometry, wheelbase and if i want to continue with the project. I also want to lower it down, most likely will run like half droop to get the stance im looking for but keep some wheel travel.
Setup i came up with for front uppers, will be running a chassis mount servo.
Chassis shots.
The all important flex shot:lmao:
Heres the body i want to run, not sure where it came from but it is a 2 piece haredbody with a bed with functional bed cover. Also cab has swing in mirrors and the headlights are made for leds. Take into acount it is just sitting on the chassis in the pics, i don't like how it looks with the high ride height.
To show the headlight and how flush the tires are with the body.
Chassis shots.
yea looks good....................
Thanks guys, i have some 2.2 mudslingers here i could try, there big but not huge. I want to lower it down a little and see if it like it, if not i have another custom chassis here thats made for leafs springs. With that chassis it would have a bed.
looks good, maybe try bigger 1.9s. irok maybe...
