Losi Night Crawler WormDrive getting hot...
The rear differential on my Losi Night Crawler is getting pretty hot when I run it.
I did some googling and I see a lot of people around the net talking about "drilling a small hole in the diff, and adding grease, then sealing up the hole with a screw."
Is that really a good idea? Any other ideas on how I can solve this without doing minor surgery?
Yes the small hole for grease is the best way to solve the issue I used a small set screw to plug the hole and added grease every few hours of run time, and another issue you may be having is a incorrect shims on the worm gear. If you want any more info I'd check out rccrawler.com tons of tips and tricks under the team losi section.
R/C Tech Elite Member
I didn't like the idea of drilling a hole, so I didn't.
I just filled my diffs with Grim Racer Marine grease. Ran the LCC in a season of comps and GTGs for over a year. Opened up the diffs for maintenance and no grease was lost and all the original gears looked like new.
Another year goes by and the grease was still in there. I cleaned it out anyway for routine maintenance but I am very impressed with that grease. No sling, high temp and waterproof plus the tub cost $3.00 and will last a lifetime.
I sold the Losi and using MOAs now but I still miss the old rig.
