3 True Position Adapters
Hey guys i offer 3 True position Adapters. If you have no idea what i'm talking about well here you go
www.overkillrc.com
Basically if you have a 3 position 3rd channel radio, you can now make it so your positions aren't left center right. Can go in any order you want
If you have a 2 position 3rd channel radio, well this turns it into a 3 postion. With every cycle of the switch it will change position,
If you have a Traxxas 2.4 TQ4 and you found out ch 4 is actually two 2 position channels and its not a 3 position channel well your in luck because this adapter will take ch's 4 and 5 and turn them into a single 3 position channel.
For more indepth description go to the above link
www.overkillrc.com
