Sponsored by:
Go Back   R/C Tech Forums > General Forums > Crawler Room
Thread Tools Search this Thread Rate Thread
Old 02-19-2011, 08:24 AM   #1
russp's Avatar
Default motor question
Hey guys, I just got my first crawler project. I got the losi comp, and tryin to put a motor/esc package together. My question is, I have a novak 17.5 ss motor layin around and was wondering if this would be usable? I noticed that the novak goat has a 18.5 motor, so the 17.5 is not much bigger..
Thanks guys
"Never argue with an idiot. They'll just drag you down to their level, and beat you with experience!"
***radiopost.com***Gens ace/hobbypartz.com***Evosports.net
+++Losi xxx-sct 17.5+++Losi 22. 17.5+++losi xxx-sct mod+++
russp is offline   Reply With Quote
Old 02-19-2011, 08:57 PM   #2
Most guys I know that run brushless run between a 17.5 and a 21.5t motor. Not sure about pinions though. Good luck with your truck!
Not by my work, but by my faith am I saved!
Team Holy Rollers
You gotta crawl before you can walk....
handicrawler is offline   Reply With Quote
Old 02-19-2011, 10:31 PM   #3
outoforder's Avatar
Trader Rating: 34 (100%+)
I'm not sure about using a brushless on a losi . I know they have worm gears and they tend to get hot.
...BASHERS INC.....
Team
Valadez
Hobbies
outoforder is offline   Reply With Quote
Old 02-20-2011, 06:34 AM   #4
a losi works best on brushless power because the worms suck so much up. the main thing to look at is it needs to be sensored or else it will cog at low speeds. run a small pinion and you should be fine.
Crawling and 1/10 CORR racing.
www.rc-ab.com
racerjim is offline   Reply With Quote
Old 02-20-2011, 07:25 AM   #5
outoforder's Avatar
Didn't know that, I like how the losi is shaft driven but still has dig in the front or rear.
...BASHERS INC.....
Team
Valadez
Hobbies
Old 02-20-2011, 09:26 AM   #6
russp's Avatar
Ok that's good to know. So do I have to use a crawler speedo? Or will a regular brusless speedo work? I also have a spare mamba max pro layin around.
Old 02-25-2011, 08:08 PM   #7
Trader Rating: 17 (100%+)
Default losi
Also throw a castle BEC in there also it will help out also ,especially if you run a high torque servo ,for steering .
Bjeepn is offline   Reply With Quote
Tamiya Sport Tuned Motor question Moogumby Electric Off-Road 8 10-22-2009 07:15 PM
Atomic Micro BB Motor question ajf Micro and Mini Scales 6 01-13-2008 10:29 AM
Axiom Motor Question Swanny Electric On-Road 22 12-10-2007 06:41 PM
brushless motor question for a 1/8th buggy conversion downunder23 Electric Off-Road 25 02-26-2007 04:15 AM
Motor Question? WRXTC Electric On-Road 45 08-06-2005 01:01 PM
