Official Axial SCX 10 Thread
#16
It started off as a scorpion kit, and then I picked up a scx chassis on eBay, and just built my own so it has the longer link rods on on it.. It seems to do real good.. 100mm shocks, weighted 1.9 honcho wheels/tires..rooster reversible, tekin 35t and 4500 7cell stick. I built a custom flat lid for the scx receiver box so I could have a secure mount for the esc... That's about it...of and the brite hummer body now..
#17
Oh okay, i have been looking at this site called rpphobby, they have bunch of parts for SCX 10, such as the panhard mount kit, 4 link truss and etc... I am new to this and i just got my SCX 10 today, so i have no clue what to get and what not to get...i have just been reading on here and rcccrawler...looking for suggestions!
#18
Just keep it up... Lots of cool people willing to help....! I think the stick setup is pretty good for an entry level scale truck... I'd like to see it sit a little higher and desperse weight a little better...but those are just my opinions...there's plenty to upgrade to look more real scale, or perform better or a little of both.. Good luck
#19
Get the battery forward, 4 link the rear with the R2J truss.
High clearance links of the front for better steering and upgrade the speedie to something with a drag brake.
Aluminium or steel links are pretty important too. Below pick is my old mans with plastic links, banana style.
Oh, this is mine BTW
#20
Thank You
#21
#22
Suspended
custom scx10
i keep adding new ideas, here is the latest, body work and cut window for roll down look also made it look like cracks in glass, more to come
#24
I plan on picking up the Honcho when the AE-2 is available in the Trail Ready. I have 3300mah Nimh packs and 4100mah Lipos - the esc can use both.
I'm wondering what kind of run times I can expect with the stock 27t motor using either battery. What batteries do you guys run and what run times are you getting from them?
Thanks.
Thanks.
#25
i'm running integy 55t with 5200mah lipo, it gives me about two hours run time
#26
Moderator
That's the cool thing about these crawlers/scalers, you can buy the upgrades or if the ladies find you handy you can make them yourself. I had the pathetic plastic links on mine as well and got tired of watching them bend and flex. So I picked up some 1/4" aluminum stock and made my own. They work great.
Moving your battery forward works much better for rock crawling. If you want to play in the mud of snow I've found that a rear mounted battery works better.
#27
novak rooster esc
45T brushed
savox 20kg digital servo ( custom mounted on chassis )
panhardbar setup
4 linked rear
all aluminium links.
rear upper and lower links bent.
aluminium 1.9 beadlocks
rc4wd winch & hook
custom steel sliders
custom steel front bumper
rc4wd 1.9 baja claws
losi 4"crawler shocks
14 working led lights incl. rock lights
some scale details
aluminium c-hubs
aluminium steerlinks
robinson racing hard steel gears
rear is undergeared
#28
