Sponsored by:
Go Back   R/C Tech Forums > General Forums > Crawler Room
Thread Tools Search this Thread Rate Thread
Old 01-25-2011, 05:23 AM   #1
Trader Rating: 57 (100%+)
Default xl-5 troubles
I have an axial scx 10 that I built I used a traxxas xl-5 speed control but i am having problems with it going into neutral. When i adjust it on my radio it changes nothing. So is the speed control bad or a radio at fault? Any help would be appreciated
thanks
josh
josh_todd is offline   Reply With Quote
Old 01-25-2011, 11:51 AM   #2
Trader Rating: 16 (100%+)
by neutral you mean the throttle cuts off when you are driving?
Dark Dragon is offline   Reply With Quote
Old 01-25-2011, 03:37 PM   #3
Default xl-5
no it stalls going forward but will go to reverse just fine ive tried to reset it and it helps for a little bit then it will do it again.
thanks
josh
Old 01-25-2011, 06:35 PM   #4
I would be willing to bet it's probably your esc. I had a vxl3 burn up so forward was about half power, and reverse didn't work at all. Good news for you is they are cheap to repalce, or even better upgrade. I have a sidewinder that I have setup with a castle link, they are so tunable it's crazy and you can get them for cheap used. I have bought two from here for $40 each, and plan to buy another soon.
Old 01-25-2011, 07:04 PM   #5
if by stall you mean hesitates before going forward but goes straight into reverse..
I believe you have to reverse the transmitter signal for throttle, which will make it go backwards when you want to go forward, and visa versa..
Then you must reverse the polarity of the motor itself.. Then the forward control will make your truck go forward.
This normally occurs if you reverse the plate that the motor and gearbox is attached... allowing for dig units etc.
hope this helps
Just keep tellin her its cheaper than real cars.... safer too
Stangas is offline   Reply With Quote
Old 01-26-2011, 04:24 AM   #6
Default xl-5
thanks for the input i will give it a try
thanks
josh
Revo 3.3 or HPI Savage 5.9 skengines Monster Trucks 21 09-25-2010 08:37 PM
Truckindad33 is a scammer Kujo Buyer/Seller dispute and Feedback discussion forum 44 07-14-2010 05:49 PM
SLASH CLASS LOVE IT HATE IT? li racer Electric Off-Road 475 05-21-2010 09:34 PM
Schulze U-Force 75, What motor? Rocksalt Electric Off-Road 11 08-23-2006 07:44 PM
