my first crawler pics....can you guys help
Hey folks... i just built my first crawler with limited resources. I am looking for " constructive criticism "....let me have it...lol... I am just wanting to know what i could good do better and different opinions from the help of you guys. Thanks
" Rangers Lead The Way "
Sua Sponte
Sua Sponte
that's funny...i appreciate it...i am thinking about getting the edge chassis. the proline is nice but a pain in the butt to take off every time i need to work on it...so i modified it. i cut the floor pan out of it and remounted the battery tray. That way i can mount my electronics on it and I put the battery in the front part of the cage....it works out pretty good.
Here are a few things I picked up that should be easy and cheap to change.
-Change out the plastic steering links.
-Move the battery to the front axle or on top of the front top links.
-3/8" delrin lower links will help it slide over rocks
-Heavy delrin skid to stiffen things up and slide over the rocks
-Weight the wheels if you haven't yet.
-Tires would help a lot too. Hammers are OK but some Rovers will make a big difference!!
Nice!
Sweet looking rig mate.
I'd change the standered driveshafts and put on a alloy steering arm though. And like others have said, some extra wheights. ( Mag wheel wheights from a tyer shop work really well. ) In the wheel rims or on the servo / axels. Ya want to keep the weight unsprung, and low.
Rock on
Rock on
nice tuber i think its got a nice look !!
I would also get shorter shocks like the Losi or traxxas big bores and start limiting your flex to help with torque twist.
i just ordered some big bores. i am a mechanic, so i have a butt load of stick weights. I run one complete wrap of the rim. I need to install my new steering linkage. I am in need of a dig....donations anyone????....i was worth a shot.....thank you guys for the compliments and suggestions...it's very motivating
you should go to rccrawler.com. it is a forum dedicated to only crawlers and has more info than you could think of.
