Berg/ MOA guys post up!
Tired of all these shafty threads Lets see your MOA's! Post full specs, and what state you run your berg in. Im pretty sure I may know a few of you from RCC. Heres mine:
Rockshow moon buggy chassis
Custom front lower links and uppers, T1E rear links
Losi shocks
Hot body rovers
86jeep steering
Wheelworks wheels from Reflection on RCC
Mamba max
Dx3/sr3000
punk dig
Castle BEC
hs5955 servo
Rear JPlockouts
I crawl with the southern guys down here in GA, and im sponsored by Brians Hobbyland
Heres some pics from a while back, and a few from the recent shock change:
Losi shocks
Hot body rovers
86jeep steering
Mamba max
Dx3/sr3000
punk dig
Castle BEC
hs5955 servo
Rear JPlockouts
I have a couple of MOA's The specs change daily though
1st up I have a berg currently with
T1E stage chassis
FXR W/bec
Punk dig
35t motors W/ 13t pinions
VP knuckles
rear lockouts
Hitec HS-7955 servo
Few tire/wheel options: wheels (VP DH's-Mayhem UCW's) tires (panther-HPI)
couple tops: CKRC bug and Proline Bug (currently un-painted)
MaxAmps 3s 800mah 40c lipo
3PKS W/spektrum rx
also have a HR power axle Moonbuggy in the works
T1E Moonbuggy chassis (currently white)
FXR Pro W/BEC
Punk dig
45t motors W/13t pinions
fubar rear lockouts
CKRC knuckles
Hitec HS-7955 servo
couple tire/wheel options: wheels(mayhem CDP's & 7's) Tires (Panther-HPI)
3PKS W/spektrum
Its still a work in progress. I need to decide on a color to dye it and get a good set of 90mm shocks.
T1E stage chassis
FXR W/bec
Punk dig
VP knuckles
rear lockouts
Hitec HS-7955 servo
3PKS W/spektrum rx
FXR Pro W/BEC
Punk dig
fubar rear lockouts
CKRC knuckles
Hitec HS-7955 servo
3PKS W/spektrum
my current berg,
CDW chump Chassis
CDW lower links
Lunsford upper links
punk dig
hitec 7955 servo
dx3r
CKRC 35t
CKRC ota steering
jeepingDoug lockouts
Vanquish slw
HB rovers
nova's foam
Losi pro grappler body
Tekin FXR
Losi shocks
CDW chump Chassis
CDW lower links
punk dig
hitec 7955 servo
dx3r
CKRC 35t
CKRC ota steering
Vanquish slw
HB rovers
nova's foam
Tekin FXR
Losi shocks
My current 2010 Comp Rig:
BWD Wedge Chassis
Mayhem Comp Double Phatty Wheels
Tekin FXR With Castle BEC
Hitec HS-7950TH Servo
Punk RC Dig Switch
Rover Tires with Pro-Line Two Stage Foams
BWD Wedge Chassis
Punk RC Dig Switch
I been running this Hot racing/kamikaze mini for a while now. Very happy with it.
Current specs:
Hot racing axles
clocked 20*
300s in front
berg lockers
40t warriors
Dual fxr
ccbec
jr 9100
homemade steering
Kamikaze zero 4.0
Kamikaze low bend front lower links w/revo ends
Kamikaze high bend rear lower links w/revo ends
Homemade 1/4' delrin uppers w traxxas 3mm ends
Traxxas Alum big bores with traxxas rod end mod
cut losi springs
mayhem prototype front wheels (no weight)
CKRC skinny rear wheels (with no weight)
White dot rovers
Nova foams
Thunder power 850mah 45c 3s
futaba 4pk
Current specs:
Hot racing axles
clocked 20*
300s in front
berg lockers
40t warriors
Dual fxr
ccbec
jr 9100
homemade steering
Kamikaze zero 4.0
cut losi springs
White dot rovers
Nova foams
futaba 4pk
