Corally SP12M - 1:12th Ahoniemi Euros Spec
#61
well just a note on the tubes that comes with the car check your left to right articulation i had one tube thats was all jacked up and had to cut one down to make the rear pod articulate left to right evenly....also the kit comes with tweak screws mounted in the furthest position(closeset to front)which i found terrable i couldnt tweak the car for nothing had like 3 guys look at it the same thing couldnt get the rear tires to come off at the same time when i moved them to the furtest rear position i tweaked the car with no problem.... any body else have this problem.....
#62
ill tell u this once we figured out all those little issues the car was one of the most dialed 12th scales i have driven.....ran mod pinks and purples were the ticket.............very easly driven........
#65
Originally Posted by subman
that part number is for a 3 cell tray is there none that fit with out modification?
Ronald
#66
News about the new 2006 car, the SP12X.
Here's some translated text (from japanese):
The new model car and the team system which from コラリー are directed to 2006 worldwide game were announced. David Spashett player and Chris Tosolini player anew team joining. Don't you think? it is expectation large in the combination of new model car SP12X.
Quotation from コラリープレースリリース
In o SP12X titanium bis standard equipment
O ceramic ball bearing, diff. ball, thrust bearing standard equipment
O superhigh grade graphite chassis
And offcourse some pictures
#67
Looks very nice.................
#68
The new car looks great. I just hope they replace the damper tubes as this is the worst part of the car.
Ronald
Ronald
#69
New 12X looks interesting. Battery hold down? Shock mount plate - single arm to motor plate, can this be stiff enough?? No wishbone for the front end. Looks like 12SP. A lot less part!!
It will be fun seeing if this works well.
Have my 12m Euro almost dialed in. Last time out - lost grip due to body. Going to fast and not enough down force.
Great car Guys!!
Great car Guys!!
#72
Originally Posted by Blink281
Anyone know when the 12X be avaiable and what it will cost?
Ronald
