Sp 12g3
Re: Sp 12g3
Originally posted by picco007
Can anyone tell me what servo fits in the 6 cell G3 chassis? A few of the micro servos that I have tried are not fitting......I would appreicate it.
Ronnie
Ronnie
i have this car, presently using hitec hs-225mg servo for the steering. those pre-drilled holes for mounting the servos wont work with my servo, and i dont know what servo will fit those holes as well. my solution is to shoo-gued the servo in place, and it holds up really well till now...in case you feel like trying out my method, just make sure that the servo's output gear is situated right in the centre of the chassis' centreline for equal steering. just my s$0.002.
Re: Thanks
Thanks, I wanted to used a servo that would fit.....Do you think an Airtronics 94145 would work?
I had a G3 as well as the SP12M and the servo I was using was an older Futaba S132SH that was a perfect drop in fit. These servos were the standard in 12th scale some years ago, but are no longer made. I even have two of the orange Novak NES-1 servos which also drop fit into most 12th scale cars.
