Go Back   R/C Tech Forums > Company/Manufacturer Forums > Corally Product & Tech Forum
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-29-2007, 12:58 PM   #1
Rick Pfeilstick's Avatar
Default corally rdx brushless roll out
just wondering what rollout to run 13.5 novak system? rdx car and running about 57 mm foam tires.... thanks
Rick Pfeilstick is offline   Reply With Quote
Old 11-29-2007, 08:21 PM   #2
kartermdb's Avatar
Send a message via AIM to kartermdb
on a track with about a 120 ft straight and rubber tires we are running a final drive of about 3.8 to 4.0 so be prepared to gear it high
kartermdb is offline   Reply With Quote
Old 11-30-2007, 10:38 AM   #3
is that 3.8 to 4.0 inches?
Old 12-01-2007, 09:19 PM   #4
kartermdb's Avatar
no that is actually final drive ratio, we dont calculate rollout on rubber tires because they are all basically the same size. But I believe a rubber tire is 63 mm, so you can calculate from there.
Mark Burt
Thanks to:
Xray - RC America - J Concepts - Trinity/Team Epic - Schumacher USA
Old 12-03-2007, 05:53 PM   #5
swopemike's Avatar
Med-large 120' asphalt straight, but technical track, we geared around a 4.8 FDR probably because of the tighter sections. That's a 43 pinion and 104 spur on the RDX. We have geared as high as 47 tooth and as low as 42 tooth. That was on 62 to 63mm rubber tires. It would be to 46 to 52 teeth for 57 mm tires. You would go down up to 20% for tight carpet tracks so that gives you a range.
Rollout = 3.14 x diam / FDR = 37.3 mm (4.84 FDR). High end 36.4 to 40.8mm for larger asphalt tracks. Low end ~29mm or so.
swopemike is offline   Reply With Quote
Old 12-03-2007, 09:04 PM   #6
kartermdb's Avatar
Thanks, we dont run on much carpet down here, we get to run outside all year round. Hope you get the gearing figured out
Mark Burt
Thanks to:
Old 11-20-2008, 08:15 PM   #7
Jereme S's Avatar
on carpet with foams i ran 39 and 88 spur with 13.5 worked good on med and large tracks
Jereme S is offline   Reply With Quote
Old 07-01-2009, 10:27 PM   #8
f2000racer's Avatar
New to brushless and I have a LRP 17.5. What's the gear ratio would one recommend on asphalt with about 100' straights? Or should I just follow the recommended ration from LRP?
Thanks.
T-Bang Motors
Corally RDX PHI
Tamiya F103RM
Tamiya Mini
f2000racer is offline   Reply With Quote
Old 07-09-2009, 09:05 PM   #9
Jeff Brown's Avatar
Thanks.
Depends what ESC you are running. If you are running a Sphere TC on profile 8 then I would start around a 4.50 FDR and check temp from there. If you are running at SPX then I would drop to about a 5.3 and start there.
Jeff
Jeff Brown is offline   Reply With Quote
Forum Jump
G4S roll bar mod - change to mugen roll bar charlesd Nitro On-Road 13 07-01-2008 12:32 AM
Corally RDX brushless...diff..??'s GSPOT Electric On-Road 2 12-08-2007 07:20 PM
Brushless Corally RDX artr lil3j R/C Items: For Sale/Trade 5 10-04-2007 06:00 PM
New corally brushless Cammer Electric On-Road 6 04-27-2007 11:55 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 04:12 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
