Go Back   R/C Tech Forums > Company/Manufacturer Forums > Corally Product & Tech Forum
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-08-2006, 08:59 PM   #1
Jeff Brown's Avatar
Default Setup Questions
Post any questions on what changes to make to your current setup. Ask any questions on what certain changes will do to your car. Ask away......
Jeff Brown is offline   Reply With Quote
Old 03-10-2006, 04:01 AM   #2
BugFreak's Avatar
My RDX is way heavy on the motor-side... am I the only one with this problem?? Tips??
Svein E. Pedersen
- tamiya4ever -
BugFreak is offline   Reply With Quote
Old 03-10-2006, 07:26 AM   #3
Jeff Brown's Avatar
Well, I am sure most people have seen that. Typically people have to add weight so I would put it on the right rear to counter balance it.
Jeff
Old 03-10-2006, 12:30 PM   #4
BugFreak's Avatar
I think I've seen the esc mounted on the right, behind the battery...?
Svein E. Pedersen
- tamiya4ever -
Old 03-10-2006, 12:39 PM   #5
Jeff Brown's Avatar
I have never seen that. I would think it would throw off the balance too much.
Jeff
Old 03-10-2006, 03:08 PM   #6
xevias's Avatar
I had my GTX behind the battery with no weight issues, but have since changed locations due to using 4200 batteries and a guy accientally reprogramming the speedo when marshalling my car. I'm at 1470g on foams with no weights and the IB4200's.
xevias is offline   Reply With Quote
Old 03-11-2006, 12:30 AM   #7
BugFreak's Avatar
Had to try... and it worked GREAT!!
With only 15grams weight on the motorside, it looked like this...
Svein E. Pedersen
- tamiya4ever -
Old 03-11-2006, 11:56 AM   #8
BlackKat's Avatar
Hey,
I have a very dialed rubber tire setup on carpet and have a quick question
I am currently not using the brackets on the rear arms that move the bottom of the shock outward. I am using the 17lb springs on all four corners of the car in the outermost hole. I know what the brackets do (give the arm more leverage on the shock) but I don't know how this will effect the car on the track. How would the car feel/drive different if I went to maybe 14lb springs in the rear with the brackets?
BlackKat is offline   Reply With Quote
Old 03-11-2006, 05:44 PM   #9
MUDVAYNE's Avatar
Trader Rating: 41 (100%+)
Hey Bug, what springs are you using?
Team Holly Rollers
Alien ArtWerX - Custom paint, paint masks, and vinyl
Tekin products all the way!!!!!
MUDVAYNE is offline   Reply With Quote
Old 03-11-2006, 05:45 PM   #10
MUDVAYNE's Avatar
Originally Posted by BlackKat
Hey,
Black, can you send me your set-up?
Team Holly Rollers
Old 03-11-2006, 05:54 PM   #11
BlackKat's Avatar
Mudvayne: Here it is. Since we run at a low traction carpet track, we run staggered tires. You might want to run the same tire all the way around though.
Old 03-11-2006, 06:53 PM   #12
Jeff Brown's Avatar
Hey,
Well, without the brackets it would seem like your previous setup required softer dampening. Which is what happens when you remove the brackets. I am not 100% sure the effect of 17lb with no extensions vs. 14lb with them. I would think that it would still be stiffer with the extensions as the dampening will increase due to the leverage. Which is why you would drop to a 14lb or even 12.5lb to get the same feeling.
Not sure how much that helped.
Jeff
Old 03-11-2006, 07:50 PM   #13
BlackKat's Avatar
Jeff
For clarification...I've never run the brackets. I'm just curious to why I should (if I should, that is) Basically: What are the advantages to running a softer spring with a bracket as opposed to a harder spring without a bracket?
Old 03-11-2006, 11:48 PM   #14
BugFreak's Avatar
The yelow one is from xray.. they are to small, but there was missing a few parts when I got it.. (second hand..)
The front springs are 17 lbs
Svein E. Pedersen
- tamiya4ever -
Old 03-20-2006, 11:00 AM   #15
Trader Rating: 18 (100%+)
Default Brian mcgreevy setup
Quick Q on this.On the sheet it says 2.5 mm "shims under couplers".Are they referring to the "balls"that the arms attach to?The roll blocks?Also,Is it just 2.5mm for the front?or for front and rear?Trying to figure this car out.First non Associated car in 15 years of racing.lol.Thanks,Mario.
lotus1 is offline   Reply With Quote
Forum Jump
Kyosho RRR Setup Questions fastrcracer Nitro On-Road 4 08-19-2008 03:05 PM
setup questions kwellst Micro and Mini Scales 4 06-24-2008 05:54 PM
Setup Questions... #iZzy Electric On-Road 9 10-26-2007 12:29 PM
SUT first run, few setup and engine questions? Cain Monster Trucks 11 08-21-2006 11:34 AM
T3 Setup Questions DraKhen99 Electric Off-Road 5 07-01-2003 08:02 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
