Go Back   R/C Tech Forums > For Sale/Trade Forums > Commercial Marketplace
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-24-2009, 04:50 PM   #1
Default Ceramic Engine Bearings
Hey guys
We have just released three sizes of ultra high performance Ceramic engine bearings. They are 7x19x6mm ceramic engine bearings, 14x25.4x6mm ceramic engine bearings and 14x25.8x6mm ceramic engine bearings. Each are made with PEEK cages and our diamond polished silicon nitride balls with proprietary internal tolerances that will allow the bearing to spin faster longer. Plus free shipping worldwide and a great introductory price of only US$11.99 for one ceramic engine ball bearing. Thanks!
ACER Racing: the Fastest, Smoothest, Lightest & HARDEST BALLS in the INDUSTRY.
acerracing is offline   Reply With Quote
Old 08-25-2009, 05:54 PM   #2
helivaguy's Avatar
what are the ABEC ratings on these engine bearings?
jammin x1 fte-novarossi top 421b.
mugen mbx5r -Novarossi plus 21-5k.
ofna hyper 8.5 -Novarossi plus 21-5.
ofna gtp 2 -IDM Picco Evo3 .21.
team magic g4 evo -Novarossi Top S5.
helivaguy is online now   Reply With Quote
Old 08-26-2009, 05:20 PM   #3
helivaguy's Avatar
ok these are ABEC 5 bearings,i will stay with my ABEC 7.
also peek material is known to shatter when dropped.
Old 08-27-2009, 09:13 AM
audacious
This message has been deleted by Marcos.J. Reason: spam from axiummotors
Old 08-27-2009, 02:16 PM   #4
helivaguy's Avatar
glad to hear that...if monty is involved they have to be good
Old 08-31-2009, 01:53 PM   #5
Our ceramic bearings feature our diamond polished Silicon Nitride ceramic balls plus a super high speed PEEK inner cage to withstand the heat and stress of your engine. Proprietary internal tolerances have been incorporated into this ceramic bearing as well.
New generation PEEK polymer was chosen for the cages because of its superior combination of strength and flexibility, high operating temperatures, and high chemical and wear resistance. The design of the cage and material used are of paramount importance for the performance of the cage as well as for the operational reliability of the bearing itself.
PEEK cages have an excellent combination of strength and elasticity. The good sliding properties of the polymer on lubricated steel surfaces and the smoothness of the cage surfaces in contact with the rolling elements produce the lowest amount of friction so that heat generation and wear in the bearing are at a minimum. The low density of the material means that the inertia of the cage is small contributing to greater speed and higher RPM. The excellent running properties of polymer cages under lubricant starvation conditions permit continued operation of the bearing for some time without risk of seizure and secondary damage.
Our PEEK bearing cages show no signs of aging by temperature and oil additives up to +200 °C (392°F). Our PEEK cage is a superior material which will outperform other cages in high stress engine applications, and will not crack.
Old 09-01-2009, 01:33 AM   #6
sangyi41's Avatar
Send a message via MSN to sangyi41 Send a message via Yahoo to sangyi41
do u have size 14.2x25.3x6mm for sirio and werks engine.i hope i can order from u front and rear bearing for my engine.hope u have it
TeamLosi 8Eight 2.0B(M2c Racing Clucth And Performance Part)
Picco P3R .21(Awesome Power)Novarossi Plus21-4C(Race Use Motor)
Dynamite 086 Tuned Pipe(Scream TUned Pipe)
(Power Hd 7150MG(TH) Power HD 9150MG(ST))
3PKS 2.4Ghz Call/Sms WIliam Tiong:+60175007932 Location(Taiping,Perak)
sangyi41 is offline   Reply With Quote
Old 09-01-2009, 02:28 PM   #7
Default Ceramic Engine bearings
Sorry but currently we only have 14x25.4, 14x25.8 and 7x19mm ceramic engine bearings.
Old 09-02-2009, 09:44 PM   #8
Default 12x21x5mm Ceramic engine bearings
We should be releasing our 12x21x5mm ceramic engine bearings soon though thanks again for the interest.
Old 09-03-2009, 12:00 PM   #9
sangyi41's Avatar
when 14.2x25.3x6 available?i planning get the 1 set engine bearing from u.7x19x6 is avaialble.but i need 1 more rear bearing is 14.2x25.3x6!!!!!!!!!!!
Old 09-28-2009, 08:49 PM   #10
Trader Rating: 18 (100%+)
Do you have front and rear bearings for the OS Speed .21. How much are they. Thanks
ForwardBite is offline   Reply With Quote
Old 10-19-2009, 01:39 PM
skimjhon
Old 11-09-2009, 01:52 PM   #11
Default 12x21x5mm ceramic engine bearings
Just released our 12x21x5mm Ceramic Engine Bearings...thanks for all your patience in waiting for these to be released.
Old 11-09-2009, 02:14 PM   #12
helivaguy's Avatar
why does the peek bearing cage fit so loose between the inner and outer race?
they seem to float or flop around in there
Old 11-11-2009, 03:10 PM   #13
Default Ceramic engine bearings at the Swiss Championships
We are proud to announce that ACER Racer and European Champion Shasa Lackner's Max Power Engine fitted with ACER Racing ceramic engine bearings won the Swiss Championships and TQ'd this weeked at the 1/12 Edelweiss cup setting a new lap record and winning all three main finals.
All in all about 10 liters of fuel have been used by Shasa with ZERO signs of wear or oxidation in our ceramic engine bearings.
Congrats to Shasa and thanks to all our loyal customers who asked us to proceed with the ceramic engine bearing project.
We will be releasing the 7x17x5mm ceramic engine bearing in 3 weeks and we are taking back orders currently. Take advantage of our low introductory prices.
Old 11-11-2009, 11:08 PM   #14
houston's Avatar
Trader Rating: 55 (100%+)
interesting
dont quite understand how you guys are selling so cheap
TEAM ONE HOBBIES / TEAM NOVAROSSIUSA / TEAM SICK GRAPHICS / [url]www.novarossiusa.com [url] / www.kyoshoamerica.com / houstonsengineservice@live.com service for novarossi engines / AKA products www.byronfuels.com / www.hitecrcd.com/www.houstonsengineservice.com/special thanks to STAV and JIM HOTTI
houston is offline   Reply With Quote
Old 11-12-2009, 07:01 AM   #15
Sure, if we get more requests for the 14.2x25.3mm bearing we will start production but at this time it is cost prohibitive-not enough requests so we couldn't keep the price low enough for everyone to enjoy.
Forum Jump
O.S. Speed owner speak up NitroNewbie Nitro Off-Road 92 09-21-2009 07:01 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45770 09-09-2009 07:19 AM
Serpent 710 Ron C. Nitro On-Road 23341 07-06-2009 10:39 AM
MUGEN JX 21 B01 PIS/SLEEVE IN A OS SPEED?? ENGINE BUILDERS HELP! yoshgixxer Nitro Off-Road 29 05-07-2009 05:50 PM
Which engine to buy? shotime Nitro Off-Road 22 11-28-2008 05:15 PM
FOR SALE - all for sale posts here Sil80 Australian Racing 10483 12-29-2005 03:37 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
