tekin setups, OFFROAD
Old 05-03-2013, 05:49 PM
BulletMan's Avatar
Default tekin setups, OFFROAD
hello race fans. thought i'd try this thread idea for TEKIN .rs setups for off road. Post for differant vehicles, tracks, traction etc.
PLEASE POST as much information as you can as to why you like your setup.... ie "2wd buggy/17.5 open/med traction/big jumps/technical layout"
know what i mean?
OK... I NEED a 2wd buggy/17.5 open/ med traction / average jumps. DO NOT need alot of bottom end.... whatcha got?
BulletMan is offline
Old 05-03-2013, 07:28 PM
know what i mean?
Wow most 2wd buggies use a much lower motor.
First you will never use the Turbo feature on dirt.
Boost 5443-20000 with a 17.5 I'd say start at 40
Current limiter 0
Test.
You might put boost at a start point in the 3000's.
Never change the 20000 end point.
Lots of setups at Tekins site just not for 17.5
http://www.teamtekin.com/hotwire/ESCsetups/index.html
I run 2wd SCT with and 8.5 and never change my RS settings just pinion swapping.
I've run this with 13.5, 10.5, 8.5
Boost 5443-20000 at 30
Current limiter 78
profile 3
chongo is offline
Old 05-04-2013, 11:25 AM
BulletMan's Avatar
the only motor i got is 17.5. atm. i just have no clue how to set it up for offroad. it was my tc blinky motor.
Old 05-04-2013, 11:36 AM
BulletMan's Avatar
Current limiter 0
Test.
Current limiter 78
profile 3
what motor timing? (endbell) and what timing.. 100?
Old 05-04-2013, 04:30 PM
Rattlesnaker's Avatar
Hey Martin! A 10.5 is a good starting point and then you can gear up or turn up the timing from there. I run that on a low to med traction track that is fairly technical
Rattlesnaker is offline
Old 05-04-2013, 05:36 PM
BulletMan's Avatar
UMMM... i ONLY have a 17.5.... how live ron.... one day i will come back for a race
Old 05-04-2013, 06:04 PM
What motor?
I usually leave mine at the factory setting and adjust timing in esc and/or pinion for top/bottom end.
It's off road on dirt which is nothing like on road carpet for traction.
you need to see and feel where the car is loose or needs bottom end for making jumps.
Then you can fine tune with endbell if you need too.
chongo is offline
Old 05-19-2013, 10:21 AM
INFERN0's Avatar
I have a spare Tekin 6.5 if yer interested dude. Ya won't need to do much esc tuning except current limiter this way.
INFERN0 is offline
