The Thompson Valley R/C Race Club is proud to present:
The 2010 Kamloops Mid Winter Challenge Race
January 22nd to 24th
This year the race will take place in the “Grand Hall Room” at our Thompson Rivers University here in Kamloops! This is a beautiful facility with lots of room for our track and pit space, all within one large room. Tables & Chairs provided. Please bring long extension cords.
Now the details:
Classes
12th Scale Stock
Any ROAR Approved Bushing 27T Locked Endbell Stock Motor
17.5 ROAR Approved Brushless Motor
4 Cell NiMh or 1s Hard case LiPo
Minimum Weight = 795g using 4 Cell NiMh
Minimum Weight = 730g using 1S LiPo
Minimum Ride Height = 4mm
Pro-10
200mm or 235mm Chasiss allowed
Any ROAR Approved 19 Turn Locked Endbell Motor
13.5 ROAR Approved Brushless Motor
6 Cell NiMh or ROAR Approved, Hard Case 2 Cell LiPo
GTP Body Shells, No Can Am or Lola Style Shells
Open Tires
Touring Stock
SPEC TIRE = Jaco Blue (One set only, marked and to be purchased at time of registration)
Minimum Weight = 1500g
Touring Superstock (FOAM)
Foam Tires
Minimum Weight = 1418g
Touring Superstock (RUBBER)
Touring Novice
Any 100% RTR Touring Car Kit with the included electronics will be allowed to run in this class
Open Rubber Tires
Tamiya Mini Spec Class (TCS Rules)
Tamiya Hop-ups only allowed, No Chassis Lightening allowed.
Tamiya Bodies Only
Hardcase LiPo up to 3000mah
Closed Endbell, Silver Can Motors Only (Johnson/Mabuchi)
Tamiya Mini Rubber Tires Only
Gearing: All Cars must use a 20T pinion
Weight = 1300g
6 Min. Races
There must be a minimum of 8 cars for a class to run. If we find some
classes not filling up, then we will make a decision 2 weeks prior to the event on wether that class
will be run or not.
Tech
Batteries
Any Roar approved, Hard Case LiPo or NiMh Battery packs will be accepted unless noted in the above classes.
LiPo packs MUST be a ROAR APPROVED HARD CASE LiPo and charged using a LiPo Sack for Safety purposes only.
LiPo Battery Voltage must not exceed 8.45 volts
Body Shells
Touring Cars must run a 2 or 4 door, Sedan style Touring Car Body (Novice is the exception)
Top of the wing on Touring Cars must be equal to or below the roofline.
Pro-10 must use a GT Style Shell. No Can Am or Lola Style Shells
Weight Restrictions
Weight restrictions will be as they are set in the above classes and will be enforced.
Touring Cars, Rubber Tires = 1500g Min.
Touring Cars, Foam Tires = 1418g Min.
12 Scale Stock, 1s LiPo = 730g Min.
12 Scale Stock, 4 Cell NiMh = 795g Min.
Mini Spec Class = 1300g Min.
Pro-10 Class = TBA
Traction Compound
Traction compound used is to be citrus/odorless based
Accepted compounds are: Corally (Jack the Gripper)
Nifftech
TQ Orange
TQ 8
Paragon Traction Compound is not allowed.
Qualifying
All Touring, Pro-10 & Mini Classes will be 6 Min. qualifiers
12th Scale will be 8 Min. qualifiers
Minimum of 3 qualifiers on Saturday with 1 on Sunday (Single A-Mains)
Tech will be made on the top 4 A-Main Finishers and randomly throughout the event.
Set-up and Practice
Set-up of the track will begin at 1:00pm, Friday and the track will be open for practice from 4:00pm to 10:00pm
Entry fees:
Touring Superstock (Rubber) and Touring Stock will be run using a spec tire this year. That tire will be the Jaco Blue. These tires will be included in the price of the entry fee for that particular class. Only one set maximum per class, per driver will be allowed and they will be marked and teched during the event. You must purchase these tires at the time of registration and cannot bring in your own tires. No exceptions. If you are running 2 rubber classes and choose to only purchase one set of tires and use that one set of tires, that is fine but once you leave registration, you cannot go back and purchase a second set. The entry fees for these particular Rubber Classes will be $65.00, which of course includes one set of tires.
First Class $35
Second Class $15
Third Class $10
Novice Class $25
Racers from Vancouver Island will pay a flat rate entry fee of $35.00, $65.00 if they run in one of the Rubber Spec Classes. If they choose to race more than one class, the cost of the entry fees for these classes will be waived. This does not include the price of rubber tires if these second and third classes happen to be Rubber Spec Classes. This is to help with the high costs of the ferry.
Hotel/Motel info comming soon. Campus Suites are available for $125 per night. They sleep 4 per room and are only 3 minutes from trackside. Special prices are being arranged for rooms at the Travel Lodge, only 6 minutes from the track. Please start to pre-register for this event via this thread or by email at:
bwende@shaw.ca
