Go Back   R/C Tech Forums > North American Regional Forums > Canadian R/C Scene
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Old 10-18-2009, 06:12 PM   #46
pcar951's Avatar
Great tire price!
pcar951 is offline   Reply With Quote
Old 10-18-2009, 07:33 PM   #47
xrayroooahhhh's Avatar
Great price for tires!!! How about pre-registration???
R
-10R5-TC5R-TAMIYA F103RM-
xrayroooahhhh is offline   Reply With Quote
Old 10-18-2009, 08:09 PM   #48
while tables and chairs are supplied please remember to bring your power bars and extension cords as they are not supplied and you could be quite aways from a plug in.
Killer Bee 1 is offline   Reply With Quote
Old 10-18-2009, 08:30 PM   #49
stulec52's Avatar
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
Corwin or Mike,
I asked a couple of pages back, but didn't hear back.
do you guys have the hall to yourselves again all weekend, or split booking?
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 10-18-2009, 10:00 PM   #50
WheelNut's Avatar
Send a message via MSN to WheelNut
How much tire wear do a set of Jaco blues go through in a race weekend at a WCICS event? Also, how much does the performance of the tire drop off as it is run more and more? Is there a huge difference between run 1 and run 5? This is probably a stupid question, but, I'm trying to do this weekend as cheaply as possible, so I wonder if it's possible to get away with one set of tires between stock TC and SS TC?
-Brad Comis
---Can West R/C---Xray---
http://bradcomis.blogspot.com/
WheelNut is offline   Reply With Quote
Old 10-18-2009, 10:24 PM   #51
adamge's Avatar
Wheel, I ran all the WCICS races last year on one set of tires for both Stock and SS. I plan to do it again this year.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-18-2009, 10:25 PM   #52
Scottmisfits's Avatar
The first couple of runs might be a little slick so do at least one practice run with those tires. By the time the mains come around, they'll be great. They'll still be good for a few club races and/or practice days after that as well.
Associated, OS, Futaba, LRP, Orion, J Concepts, Byrons
PM HobbyCraft
Support your local
Local 496
Frantic Racing (Est.1988)
Scottmisfits is offline   Reply With Quote
Old 10-18-2009, 10:32 PM   #53
WheelNut's Avatar
Really? Woohoo!! I should be good with one set then.
-Brad Comis
Old 10-19-2009, 06:44 AM   #54
You get 1 set for the weekend and you can only use the tires provided. When I stripped a wheel in Lethbridge last year I had to buy a single tire for $10.
I'm still running some WCICS tires on my TC from the Calgary race. Must have 30 runs on them and there still sticking.
chongo is offline   Reply With Quote
Old 10-19-2009, 07:47 AM   #55
fullout's Avatar
Send a message via MSN to fullout
It's kinda like the energizer bunny. They just keep going. i do change mine a little less often then 30 runs but it's just for peace of mind.
fullout is offline   Reply With Quote
Old 10-19-2009, 08:40 AM   #56
adamge's Avatar
That is a good point. They definitely take a practice couple runs to come up to full traction. Also, at $30 and with the next WCICS race being in like January, it might be a smart move to buy a second set just so you have another set to race locally in the interim. I'm toying with that idea...
-Nietzsche
Old 10-19-2009, 08:51 AM   #57
Just be aware that if you do that you must run your SS in SS and your stock tires in stock. You can't buy another set just to throw them in your pit bag.
PM HobbyCraft
Support your local
Local 496
Old 10-19-2009, 04:47 PM   #58
WheelNut's Avatar
Oh, so if your running two touring classes then you need to buy two set of tires? You can only use set A in SS heats and set B in stock heats? Can't use A in SS and A in stock?
-Brad Comis
Old 10-19-2009, 05:56 PM   #59
yes you can run 2 classes with 1 set of tires...but...you can't as previously stated buy 2 set of tires and only run 1 set. The tires are marked for the specific class or classes they will be used in. So ( if you have 2 sets of tires ) if you run stock and your tires are labeled ss you will fail tech and visa versa. But if you have 1 set they would be labeled for ss and stock and be ok. I hope i'm not confusing you more!
Stu asked if we have the museum to ourself the answer is yes from Friday to Sunday around 5. That also means that it will be locked and alarmed overnight so you can leave your stuff there if you wish.
Mike
Old 10-19-2009, 07:44 PM   #60
rc pete's Avatar
Brad, I find the tires have the best traction in the first few runs... between run 2 and run 8-12, depending on how hard you are on them.
Look for a wear line that eventually starts developing near the inside edge of the tire patch. The more obvious that line gets, the more the tire is thinning out and the tire patch will squirm more under load than it should. Because the wear is gradual, you might not notice that until you put on a new set of scrubbed tires for a direct comparison.
Hot Bodies USA - HPI Racing - Atsushi Hara Racing Products - PM Hobbycraft - Raceway Hobbies - carcar.ca - www.virtualrc.com
rc pete is offline   Reply With Quote
[IMG] code is Off
Forum Jump
Carcar Ophidian Canadian R/C Scene 5683 Yesterday 01:11 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
