Go Back   R/C Tech Forums > North American Regional Forums > California Racing
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Thread Tools Rate Thread
Old 09-30-2009, 01:22 PM   #1276
downtempo's Avatar
Send a message via AIM to downtempo
Originally Posted by timmig View Post
Any of the F-1 Tamiya car guys interested in running on carpet? I tried my 103 out last monday and it handled great on the carpet with the same setup I used outdoors at the Tamiya track!! I've got to get a new speed control in it-- I can't seem to get full-power with the Tamiya unit in the car. I'm digging out an old Novak speed control from my 90's 1/12 scale cars to use!! It's just a brushed motor right? Should be compatible.
Tim
If mine and Cuda's work schedule allow it, I am sure we could make a class of it. I won't make it tonight because I am quite a ways away from the track and need a bit of warning so I can make the drive.
Carpet is unreal with these things, sooo much fun.
downtempo is offline   Reply With Quote
Old 09-30-2009, 09:26 PM   #1277
Trader Rating: 16 (100%+)
Originally Posted by Granpa View Post
Actually, I'm using the same diameter tires you are on my fwd Mini. Most of the fwd Mini guys are using the 60mm tires tho. I just felt that the present speed differential was too great to make it much fun for the 4wd Minis. The closing rates on the straights is too great to make it safe for either one of us. Whatever you'd like to try is fine by me. It's a lot more fun if the cars are more closely matched for everyone concerned. One of the 4wd Mini guys is the one who suggested the change in gear ratios to make the racing more interesting.
That was me who made the suggestion to you. I do remember you saying that with equal gearing that the silver can motor is much faster than the black can motors. I only have the ABC series handout black can motor, otherwise I'm eager to give it a try.
Contrast Neo 2.5 HR
PMT tires
V-Speed Engines
Mielke Modelltechnik pipes
Nomadio React
speed-e is offline   Reply With Quote
Old 09-30-2009, 09:54 PM   #1278
Okay, it was a great suggestion. Moving over in a turn to let a faster car thru is one thing, but giving way on the straights is problematic. I've whacked the wall more than once trying to do that and broken more than one wheel or other parts in the attempt. Racing is a lot more fun if the cars are a little more equal in speed and the passing is done in the corners rather than one car just blowing another one off by 5-10 car lengths down the straight.
Put my ABC back together after a total tear down. This one has a nasty habit of "hooking" a corner on exit. I'll have ask you about that and see if you know a fix or what the problem might be. It really isn't much fun to drive.
Granpa is offline   Reply With Quote
Old 09-30-2009, 11:34 PM   #1279
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Bob...if you want me to take a look, i will gladly get your car to stop hooking. It just needs a couple of adjustments.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
OC Circuit: http://socal.rcracing.com
CFX Paintworks:www.cfxpaintworks.com
Myspace.com/occircuit:http://www.myspace.com/occircuit
|RCGT|HPI|HOTBODIES|SPEEDPASSION|HITEC |PARMA|SPAZSTIX|IWATA|RPM|PENGUIN RC|
charlie_b is offline   Reply With Quote
Old 10-01-2009, 10:44 AM   #1280
Thanx CB. So far it's been a really frustrating experience. On corner exit it either hooks into the corner when accelerating or some times it squirts out away from the corner. Scary car to drive.
By the way, how do you like my use of highly technical terms to describe the handling characteristics of my ABC. I'm especially fond of scary.
Old 10-01-2009, 12:10 PM   #1281
any minis coming out tonite.?
JOHNSON T
MONTEREYPARK AUTO BODY
TEAM INTEGY
ABC MINI,M05,M03,TAO5IFS=RCGT
sgvrcboy is online now   Reply With Quote
Old 10-02-2009, 12:55 AM   #1282
Where did everyone go?????? Rebuilt my ABC and it was cured of most of it's nasty habits and no one shows up. There's at least another .5 sec in the car so I'm looking forward to seeing if I can extract it. I'll probably run my M05 next week as a couple of sets of steering wipers found there way to my workbench.
Mike D. and I had a great race for second with Mike hanging on to take the spot and Eric Long Gone was long gone. TDK had his struggles with the dreaded traction roll and Dangerous Don wasn't dangerous tonite. The 12th scale race was more like a very hi speed Mini race with all the bumping and banging and barrier walloping that went on. It wasn't pretty, but fun to watch. All in all a good nite. Too bad you guys missed all the fun.
Old 10-02-2009, 05:17 AM   #1283
RaceBucks's Avatar
Wish I could have been there; had to oversee a rough night of homework with my daughter. Got to see some of it on LiveRC; you and Mike had some back and forth. Planning on bringing the fleet on Sat, want to test a new 1/12th scale body.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is online now   Reply With Quote
Old 10-03-2009, 10:44 AM   #1284
OC/RC Raceway's Avatar
Carpet update!
It looks like we will be doing some rearranging of the on road track very soon,
Moving the drivers stand and extending the track width 5 additional feet.
We had a great night of racing Thursday which included (5) 13.5 sedan entries the top 3 qualified within .4 sec of each other!
Racing is only $10.00 first class and $5.00 for your second
The turn outs for racing have been very low (to say the least) however I will continue to work hard to get all of you guys here to play!
I want nothing more then to see the on-road track succeed!!!!
"Don't fear the CARPET!"
IT'S YOUR FRIEND
Peace
RB
OC/RC Raceway is offline   Reply With Quote
Old 10-03-2009, 09:34 PM   #1285
Brandon and I should be back out this thursday. My RCGT car is about ready. Bob.
prdquik is offline   Reply With Quote
Old 10-04-2009, 08:28 PM   #1286
timmig's Avatar
There's a LOT of Tamiya F-1 cars out there. COME ON OUT AND PLAY on the carpet. Your outdoor Tamiya setup will work fine. Carpets CLEAN RACING!!!
Let's figure out a night you'd like to do it? THursdays???
Mondays???
Tim
timmig is offline   Reply With Quote
Old 10-04-2009, 10:30 PM   #1287
HeliYogi's Avatar
Default F1 This Thursday oct 8
Mondays???
Tim
I will probably make it with one or two other F1's drivers around noon - 1:00 PM
Who else says I?
Forty something and still playing with toy cars…
F103R / F104 Pro / "C" Chassis C-11 body
HeliYogi is offline   Reply With Quote
Old 10-04-2009, 10:55 PM   #1288
lightfoot's Avatar
Who else says I?
F1 this Thursday sounds good...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 10-05-2009, 07:38 AM   #1289
downtempo's Avatar
I will dust off the f1 for Thursday.
Old 10-05-2009, 08:41 AM   #1290
F N CUDA's Avatar
Trader Rating: 15 (100%+)
I'll try, sounds like fun and Robert would dig it too!
Craig Hammon
F N CUDA CHASSIS BRACES FOR SC10 TRUCKS
Lately only runnin cars and trucks that look like cars and trucks.
SC10, F103, Trans Am 'cuda, M05 Mini, Saleen Mustang, Hyper10 SC 4x4
F N CUDA is online now   Reply With Quote
Forum Jump
OCRC Raceway robertbl California Racing 5595 Today 06:08 PM
West Coast R/C Raceway & Hobby Garage In So. Cali! DannyS California Racing 2462 Today 05:37 PM
TAMIYA F103 RM energyracing Electric On-Road 2173 Today 02:44 PM
West Coast RC Raceway Onroad Racing! charlie_b California Racing 245 11-18-2009 04:11 PM
The Speedtech RCGT Showdown Hebiki Racing Forum 1296 11-14-2009 04:42 PM
Losi 1/8 8ight E 4wd tyhodge07 Electric Off-Road 3497 11-13-2009 08:09 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
