Bending Corners Raceways, Carpet, Asphalt, We got it!
#46
Originally Posted by Jon Kerr
No foam tire sedan class?
the whole nation runs foams on tc. So much faster then rubber. come on raff get with the program
#47
Originally Posted by RAL
12th Scale!!!! "It's on like Donkey Kong!" Ultimate better stock up on Jack the Gripper and foams!! Less than a month till showtime!!!
#49
The Track Needs Attendance Most Importantly
Originally Posted by howard hudson
ya
#51
Originally Posted by TRESFR
I support Raffel in his choice of rubber tires for Sedan. He needs a lot of racers to support his ideas and rubber tires makes it easy to race two days on the weekends. Minor setup changes from high bite asphalt, ex. no switching chasis or needing to run sway bars or needing a second car for that matter. I agree foam is nice on carpet but maybe if attendance is high and he has not scared away the novice/intermediate racers with foam we then can phase into a foam tire class. There is always foam for 12th scale.
#53
RELAX!? I'm perfectly calm...ehheheh.
Don't misunderstand me, I am as STOKED as everyone else at the thought of having another permanent track in So Cal, especially a carpet track!! I just expected that it would be foam, as the majority of carpet races (Nats, Cleveland, Snowbirds, etc) are foam....and yes, IIC has both foam and rubber classes.
#54
Location: Bending Corners R/C Raceway(s) 2190 North Canal Street Orange, CA 92865
Foam & Rubber
J Filipow - we've got cha. Additional information will be issued addressing Foam Tires for TC but we didn't want everyone running up to their local hobby store purchasing foams and then read the class requirements and discover that they could not run foams. Basically, there will be limited classes allowed to run foam. I believe, but I'm not 100% as this was not my area of detail, that there will be foam tires in the Expert & Pro classes only.
- RP 24's & RP 30's will be the spec rubber tires for novice and sportman classes.
- Ride height minimum is 5mm
- There will be a required tech inspection for every car of every race.
Did you subscribe to the mailing list? Once all of the information is worked out, you will get the FINAL INFORMATION on all of your questions.
- 2 WEEKS TO CARPET AND WE ARE ON SCHEDULE -
[email protected]
[email protected]
#55
In my opinion foam sucks Rubber will last muuuuuch longer and is funner to drive... car setup is more important, and you don't have to true the stupid tires I believe that this year the Stockton track is going to do rubber for all TC classes except mod which will be foam (like the prior 5 years!) Last year becasue of the nats they tried to make all classes foam, but the lower level guys hated it, so they opened up rubber classes which effectively cut all thier heats in 1/2... some would do rubber and some would do foam, neither class having a full heat... seriously now how fun is stock foam???
#56
seriously now how fun is stock ???
#57
In my opinion I think it's hella fun, tighter racing and better battles... not to say 19 and mod don't battle, stocks just easier
#58
#60
Originally Posted by D_Ames
Rubber tires are for asphalt
