Go Back   R/C Tech Forums > International Forums > Brunei R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Thread Tools Rate Thread
Old 09-03-2009, 11:25 PM   #61
CH Hobbies's Avatar
ARRIVE SOON
ROAR CERTIFIED LIPO BATTERY ACORN RACING
ACORN 3200 MAH LIPO 25C 2S1P ROAR
B$ 88.00
ACORN 4200 MAH 30C 2S1P LIPO ROAR
B$128.00
New Roar lines up ACORN RACING Lipo Battery
Acorn Racing LiPo batteries using the latest technology in LiPo batteries. Offers extremely high voltage and sensational performance and are specially designed and tailor-made to perfectly fit into the most popular r/c models on the r/c market!
Featured in a durable hardcase to keep the cells from being damaged during use. At the same time it features a transparent hardcase to see the mechanical cell condition and trick looks. The new LiPo 3200-25C and 4200-30C features same dimensions as standard 6-cell Sub-C battery packs and fits in all standard 1/10th scale onroad and offroad cars. The hardcase also features some vertical standard Sub-C cell bulges to securely fit standard Sub-C pre-cutted chassis. So an accurate and firm fitting in each situation is guaranteed.
Specifications
Weight 135g
Cubic capacity 3200-4200
C-rate 25C-30C
Dimension 139x47x23.5mm
Configuration 2S1P
CH Hobbies is offline   Reply With Quote
Old 09-03-2009, 11:36 PM   #62
CH Hobbies's Avatar
PROMOTION COMBO
XCHARGER + ACORN 3200
B$168.00
XCHARGER + ACORN 4200
B$188.00
G.T. Power A6-D + ACORN 3200
B$ 188.00
G.T. Power A6-D + ACORN 4200
B$ 208.00
Old 09-03-2009, 11:42 PM   #63
Zasvak's Avatar
Send a message via MSN to Zasvak
Originally Posted by CH Hobbies View Post
NEW LRP BATTERY ARRIVED
The new power packs represents the next generation of powerful NiMH stickpacks featuring higher capacity, outstanding power delivery, lower internal resistance and a completely new and stylish design.
The packs can be used in all R/C racing applications.
On the technical side the new stickpacks have been improved to the max regarding the following areas:
• Higher cycle capability
• Improved quality
• Higher voltage.
All battery packs are supplied pre-assembled and ready-to-use including connectors. Only single-cell shrink wrapped cells by LRP are used in each LRP stickpack. Each cell has passed quality control and durability tests before it becomes a LRP stickpack.
Only high-quality LRP cells are used in LRP stickpacks – just BLUE IS BETTER!
hw much is the 5000mAH battery?
Zasvak is offline   Reply With Quote
Old 09-04-2009, 07:38 PM   #64
CH Hobbies's Avatar
Hi, Zas,
Lrp Nimh Battery Price added on page 4
Thanx
Old 09-24-2009, 11:16 PM   #65
CH Hobbies's Avatar
PROMOTION COMBO
"Promotion will End Until 30th September 2009" Stock Limited
B$168.00
B$188.00
B$ 188.00
B$ 208.00
Old 09-27-2009, 10:44 PM   #66
Thumbs up
helloo...chris...u have any 1/8 EZRUN-150A-SD ESC and EZRUN-4465SL(KV=2000) Motor ...can u order it...
MonSterTruckz is offline   Reply With Quote
Old 10-11-2009, 07:35 AM   #67
Default Xceed bodyshell audi A5
Hi CH Hobbies,do u have the latest xceed bodyshell?If yes pse pm me the price with post to w.m'sia.TQ
cwai101 is offline   Reply With Quote
Old 11-07-2009, 12:06 AM   #68
CH Hobbies's Avatar
COMING SOON
SPARROWHAWK XXB, 1/10th Scale R/C 4WD Electric Powered Off-Road Buggy Fully assembled with complete ACE RC JG-PS3i 2.4G radio and Brussless power system
ntroduction:
Brushless Power Inside, Stunning Performance Outside!
The SPARROWHAWK XXB is Thunder Tiger's first-ever brushless motor-equipped 4WD 1/10th scale buggy / stadium truck. And don't worry... the ACE RC brushless system rocks !
The SPARROWHAWK XXB is factory-equipped with the latest ACE RC brushless ESC & RIPPER brushless motor to push the electric-powered R/C car into the next ultimate level. Packed with the latest technology, the SPARROWHAWK XXB is simply unbeatable.
Thunder Tiger's RIPPER brushless motors are sensorless-type motors, and that means nearly twice more efficient than brushed motors but with much less maintenance!
If you are seeking higher speeds, more extreme torques, radical accelarations, then the SPARROWHAWK XXB is exactly what you are looking for!
Specification:
Wheelbase(mm / in.) 10.03in.(255mm)
Weight(g/ lbs.) 47.3oz.(1340g)
Length(mm / in.) 15.51 in.(394mm)
Width(mm / in.) 9.784 in.(250mm)
Height(mm / in.) 5.70in(145mm)
Ground Clearance(mm / in.) 1in.(25mm)
Motor BLC-40C brushless electronic speed control
Content:
1.- Factory-assembled chassis with installed electronics
2.- Printed and trimmed body complete with decals
3.- ACE RC R/C Cougar 2.4G pistol type transmitter
Note: AA-sized batteries (8) for transmitter, and six-cell Ni-MH sub-C battery pack and charger sold separately
Features:
100% factory-assembled and printed
•Composite tub chassisw/countersunk battery tray
4WD shaft driven off-road buggy/truggy
•Front and rear universal (CVA)
? oil-filled coil over shock absorbers w/ aluminum caps
•Standard competition slipper clutch
•Full ball bearings on axles
•Cast aluminum motor plate and mount
•Ultra long racing suspension arms
•Hardened-steel gear differentials
•Hardened-steel adjustable turnbuckles and steering tie rods
•Race ready glued wheels and tires
•ACE RC Cougar P3 2.4G radio gear w/ pistol transmitter
•ACE RC BLC-40C brushless electronic speed control
•RIPPER brushless motor IBL36-540C 3900Kv/3300Kv
•Fully upgradeable with hop-ups
B$580.00 ONLY
Forum Jump
1/12 forum ovalnator Electric On-Road 32786 Today 04:11 PM
**The Australian 12th scale thread** TomB Australian Racing 332 10-08-2009 01:27 PM
R/C Drifter chipsmore Brunei R/C Racers 79 06-16-2009 01:16 PM
IIC Warm-up Race sponsored by Jaco at Competition Hobbies in Tucson, AZ turd ferguson Racing Forum 227 08-27-2007 12:35 PM
Another San Diego County Track! threeEwes Racing Forum 174 03-10-2004 01:36 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
