COMING SOON
Directed by World Hydro Champion Jorgen Andersson, the Outlaw features 7.5cc competition racer with lots of friendly designs, which are suitable for any entry level novel who would dare to try this marine monster.
This Deep Vee comes with Thunder Tiger PRO-46M installed which has centrifugal clutch system so you can stop the boat in idle. Four aluminum clutch shoes make this clutch system perfect without slip.
Belt start for this racing boat that you will need a torque starter.
A flexible shaft is applied with Telfon guide tube. Plenty of CNC machined aluminum parts installed in factory and ready to run.
High performance Prather 230 racing propeller and racing pipe included that feature a racing Deep Vee you will be proud to own.
Advanced cooling system that has dual intakes in rudder, 3mm water line, water cooled cylinder and manifold. All of these to make sure Outlaw has peak performance in cool.
Very good design on the Quick-Remove canopy. The strong magnet is applied so user can open the canopy very quick which help you tune the engine or maintain the boat in short time with ease.
Just follow the instruction to break-in the engine then you can enjoy the boating. Need to watch out the sharp water fins at transform in operation. 15% nitro fuel is suggested and running time is about 8~10min.
Are you ready to get wet and try this screamer?
Available Frequencies:
5213-F4: 27mhz
5213-F8: 40mhz
Specification:
Length: 4.29" (1,090mm)
Beam: 12.4" (315mm)
Height: 9.6" (243mm)
Weight: 7.7lb (3500kg)
Engine: Powerful water cooled Thunder Tiger PRO-46M Installed
Radio: Jaguar 2CH Pistol Radio Included
Features:
1. Pre-painted Fiberglass (FRP) Hull w/Quick-Remove Magnet Hatch Cover
2. Water Cooled PRO-46M Engine w/Centrifugal Clutch
3. Anti-Vibrated Aluminum Engine Mount
4. Water Cooled Manifold w/efficient Tuned Pipe
5. CNC Machined & Anodized Aluminum Parts
6. 100% Factory Well Assembled and Ready To Run
Item needed to start (Not included):
-Torque starter
-15% Nitro Fuel
-12 pcs pf AA Batteries for transmitter & receiver
PRICE B$750.00
