Go Back   R/C Tech Forums > International Forums > Brunei R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Thread Tools Rate Thread
Old 04-20-2009, 06:39 AM   #16
CH Hobbies's Avatar
Just Arrived
NEW LRP SXX
First Batch Stock are limited , please kindly contact us for more info.
CH Hobbies is offline   Reply With Quote
Old 04-20-2009, 06:47 AM   #17
CH Hobbies's Avatar
Just Arrived
New LRP X12 3 and 3.5 T
+ YouTube Video
Old 04-20-2009, 06:55 AM   #18
CH Hobbies's Avatar
ARRIVED
Xray XII
Old 04-22-2009, 01:05 AM   #19
CH Hobbies's Avatar
ARRIVED
MR-DR4K Dr.4K Discharger
The Dr.4K is a state of the art digital discharger system for Sub-C size rechargeable batteries for R/C use. With technology developed by our team of R&D, Dr.4K is free from the insertion direction or polarity of battery packs by new Free bi-polar system technology. The Dr.4K can discharge 1~6cells or packs.
FEATURES
1.Auto cut off system
2.Individual discharge
3.Free bipolar system
4.Equalizing-Conditioning
5.Adjustable conditioning time
6.Wireless operation
SPECIFICATIONS
Dimensions........................................ ..............................161x94x52mm
Weight............................................ .............................................454g
Number of cells(Ni-MH/Ni-Cd)..................Sub C type 1~6cells (1.2~7.2V)
Max discharge current........................................... ...........................5A
Dicharge cuttoff voltage...............9V(Equalizing), Adjustable(Conditioning)
Input voltage........................................... ..............................DC12~14V
Discharging mode.............................................. Equalizing, Conditioning
Key............................................... .................................................. ..1
Cooling........................................... .........................30x30mm single fan
Old 04-22-2009, 01:07 AM   #20
CH Hobbies's Avatar
ARRIVED
MM-CTXD2B CTX-D2 MARC RHEINARD LIMITED EDITION
Developed functions of CTX-D2 Platinum
1. Protector against static electricity equipped.
2. Black background LCD
3. 1~6 single cells or packs can be discharged.
4. Much more accurate discharging rate and voltage reading.
5. A heat sink is attached to resistors for stability.
6. High RPM dual ball bearing fans for cool operation.
7. Perfect protection system against reverse polarity.
8. 5 polarity guide posts to ensure battery pack is inserted correctly.
Specifications
Dimensions
196x104x62mm
Weight
665g
No. of cells
1~6
Discharge current
5A / 30A pulse
Cut-off voltage
0.0(dead short)~1.20V(adjustable)
Input Voltage
10.0~16.0V
Discharging Capability
0~9990mAh(adjustable)
Discharging Modes
Linear 5A, Dead short, Pulse 30A
Keys
4
Cooling
IC controlled dual ball bearing fan x 2
IMPORTANT INFORMATION-PLEASE READ CAREFULLY BEFORE USE
1.Always ensure the CTX-D2 is connected to a suitable 12V power supply and the power is ON before placing any batteries in the tray.
2.Always ensure you place your batteries correctly in the tray-the battery bar location on the battery pack MUST match with the battery bar diagram on the CTX-D2.
3.Always ensure the polarity of your batteries match with the '+' symbol on the CTX-D2.
For further information, please refer to Page 2 of the CTX-D2 Instruciton manual.
The CTX-D2 is a state of the art microprocessor based discharger system for Sub-C size rechargeable batteries for R/C use. With CTX technology developed by our team of R&D, factory team drivers and world champions-Andy Moore, Atsushi Hara, Marc Rheinard and Surikarn Chaidajsuriya. Muchmore introduces the next generation of discharger for serious R/C drivers. The CTX-D2 is linear or pulse type discharger and can discharge 1,2,3,4,5,6cells or packs.
- Black back ground LCD with 16x2 characters
- IC controlled cooling fans
- Latest data memories
- External port for communications with computer
Pulse discharge is new discharging method which is able to check your batteries runtime and Internal Resistance at high discharging rate 30A without creating overheat. 30A Pulse discharged runtime is shorter than 30A linear. Therefore, it is much closer to the Modified race's discharging rate. You can select your best batteries before race at table benchmarks.
CTX-D2 measures IR during Pulse discharge at 2minutes after actual discharged.
Lower number of IR means it has more punch.
According to out test, new batteries of IB4200 (race level) show Runtime 480~520sec and IR 6~8
on the CTX-D2.
Old 04-22-2009, 01:09 AM   #21
CH Hobbies's Avatar
ARRIVED
MR-BHB2 Battery Heatsink 2
Provides even heat dissipation of each cell, resulting in balanced temperature of the pack when charged or discharged under hot weather conditions.
Tight fit for sub-C size battery, providing maximum contact to the surface.
Striking anodized aluminum case.
Connectable to Cell master charger or DC12V.
Old 04-22-2009, 01:11 AM   #22
CH Hobbies's Avatar
ARRIVED
MR-12FK 12v cooling fan stand
Old 04-22-2009, 01:33 AM   #23
CH Hobbies's Avatar
ARRIVED
MR-TMCB THERMO ELECTRIC MOTOR COOLER
Thermo-Electric motor cooler is actually a heat pump which cools the temperature of R/C Motors using a Peltier effect. When a 12V DC current is applied to the module, heat transfers from one side of the thermoelectric module to the other.The cold side is attached to the heat sink. Put your TMC on your motor before you start, the TMC will reduce the temperature of your motor almost to sub-zero temperatures. The prototype of TMC was tested by World champions - Marc Rheinard and Surikarn Chaidajsuriya at the 2005 TITC race in Thailand. Under extremely hot weather condition (the temperature of the track surface was over 60deg.C) the TMC delayed their motor's heating. As a result, their motors were free from the usual problems.
Specifications
Size 52x58x72mm
Weight 178g
Amp draw 3.0~3.8A
Input 3.0~3.8A
3 colors/colours of choice Black, Blue, Purple
+ YouTube Video
Old 04-23-2009, 02:31 AM   #24
CH Hobbies's Avatar
Arrived
Powercore Multi-Purpose Suitcase
Description:
Yeah Racing has launched a new multi-purpose suitcase, which is stylish and offer more functions, though not deluxe. It is easy to carry as middle sized with light-weighted. Come on, it¡¦s inexpensive, why pay more somewhere else?
Feature:
For: Power Supply units, Chargers & Batteries.
Material: Aluminum & ABS Plastic (with Foam)
Color: Black
Aluminum and High Quality Plastic Hard Outer Shell with Finished and Stippled Surface.
Custom-Cut Foam Component to Fit Different Sizes of Power Supply Units, Chargers & Batteries.
Two Layers of Foam with Storing Space for Wires.
High Density Foam to Protect the Products.
Lockable Latches with 4 Keys Included.
Specification:
Exterior Dimension: 310mm x 260mm x 95mm
Interior Dimension: 300mm x 250mm x 60mm
Charger Available Size:130mm x 80mm x 25mm, 140mm x 100mm x 25mm, 165mm x 100mm x 25mm, 140mm x 115mm x 25mm
Batteries Available Size: 145mm x 45mm x 25mm (Can hold 4 pcs Li-Po Batteries)
Power Supply Available Size: 175mm x 70mm x 25mm, 175mm x 95mm x 25mm)
Old 04-23-2009, 02:35 AM   #25
CH Hobbies's Avatar
SOLD OUT
Radio Carrying Case (BK) For Futaba 4PK / Spektrum DX3R & DX3S
Description:
The Yeah Racing (#YA-0099) Radio-K Aluminum Pistol (Wheel) Radio Carrying Case (BK) designed to fit Futaba 4PK / Spektrum DX3R & DX3S, it can protect your transmitter from damage, and contains custom-fit foam padded interior. The custom-fit foam is pre-cut and flexibly to fit your radio in a perfect position. The custom-fit foam provides plenty of room for other RC accessories storage as well. It¡¦s easy carrying with light-weighted material.
Feature:
For: Futaba 4PK / Spektrum DX3R & DX3S
Color: Black
Custom-Cut Foam Component to Fit the designated Stick Radio and Accessories.
Two Layers of Foam with Storing Space for Accessories.
Secure Latches.
Comfort Handle.
Specification:
Exterior Dimension: (L)37.9cm x (H)22.9cm x (W)18.1cm
Interior Dimension: (L)36.2cm x (H)20.3cm x (W)17.4cm
Available Foam Size For Radio: (Length with aerial) 33.5cm, (Length without aerial) 23cm, (Width) 17.5cm, (Depth) 7.4cm
Available Foam Size For Accessories: 1 x (12.5cm x 4.6cm x 4.1cm) & 1 x (5cm x 4.5cm x 4.1cm) storage spaces for accessories.
Old 04-25-2009, 12:15 AM   #26
CH Hobbies's Avatar
Just Arrived
Old 04-29-2009, 07:33 AM   #27
CH Hobbies's Avatar
Just Arrived
VTEC 1/8 Off-Road Buggy Suicide wheel pre-mounted - SUPER SOFT Compound
LRP electronic is releasing the next competition tyre of its 1/8 Buggy tyres line - excellent qualifying tyre!
The LRP R&D team and team drivers have specially developed a new thread design with small and fines pins, perfect for hard packed, high traction tracks or qualifying runs. The VTEC 1/8 tyre provides highest grip and lowest wear based on a special compound of high-quality rubber. In addition, the all new tyre features pre-cut venting holes resulting in highest performance through best air circulation. In combination with the moulded foam tyre inserts, tyre wear is reduced to a minimum. All these features combine into maximum tyre performance on all track surfaces.
Suicide:
• tread design with very fine pins, suitable for hard packed or humid race tracks
• excellent qualifying tyre
• including moulded yellow foam tyre inserts
Proven in many successful races by the LRP 1/8 LRP Offroad Team!
Features
Thread design with very fine pins, suitable for hard packed or humid race tracks
Excellent qualifying tyre
Highest Grip and longest lifespan
inclusive of moulded yellow foam tyre inserts
Lowest tyre wear
pre-glued and balanced
Compound identification on the side wall
Special gluing system for best reliability
Pre-cut venting holes
Old 05-04-2009, 08:35 AM   #28
CH Hobbies's Avatar
ARRIVED
LRP Brushless + Brushed Cooling Set
Excessive motor temperatures lower the efficiency and the power of a motor. This kit achieves a considerable reduction in motor temperature during the race and keeps motor power up!
• Fits all 540-type brushless and brushed motors
• Connection to 4 to 6 cells
• Oversize 40.0 x 40.0mm highspeed fan for maximum cooling power
• Blue anodised aluminium heat sinks with 11 cooling fins for maximum heat dissipation
• Lightweight design
Old 05-06-2009, 08:12 AM   #29
CH Hobbies's Avatar
Just Arrived
LRP Ultimo Drift Brushless Speed-Control
Ultimo Drift Speedcontrol has been specially developed for the demands of both the parking lot drifter and the serious competition drift racer.
LRP enters the world of drifting, the Ultimo Drift Speedcontrol has been specially developed for the demands of both the parking lot drifter and the serious competition drift racer. Get into the exciting world of drifting. Install the LRP ULTIMO Drift Speed-control in your car and be amazed!
Unbelievable smooth throttle control and special drifting brake profiles, including handbrake effect, will let you slide around the corner with maximum control and style. Blue metallised case for that cool and stylish drifting look!
DRIFTING CAN`T GET ANY EASIER THAN THIS!
FeaturesSpecifications
AutoCell System – Automatic NiMH/LiPo adaptation
Special drifting throttle- and brake profile including handbrake effect
ADVANCED Digital with 4 adjustable modes
Brushless + Brushed: Forward/Brake/Reverse + Forward/Brake
Automatic brushless/brushed adaptation
Internal-Temp-Check-System
Sensored technology
Multi Protection System
Metallised case for cool look
Old 05-09-2009, 03:22 AM   #30
CH Hobbies's Avatar
Special Promotion Price
YOKOMO DRIFT KIT
PROMOTION PRICE KIT ONLY B$300.00
PROMOTION PRICE COMBO B$550.00
Sold Out
Forum Jump
1/12 forum ovalnator Electric On-Road 32784 Yesterday 06:48 PM
**The Australian 12th scale thread** TomB Australian Racing 332 10-08-2009 01:27 PM
R/C Drifter chipsmore Brunei R/C Racers 79 06-16-2009 01:16 PM
IIC Warm-up Race sponsored by Jaco at Competition Hobbies in Tucson, AZ turd ferguson Racing Forum 227 08-27-2007 12:35 PM
Another San Diego County Track! threeEwes Racing Forum 174 03-10-2004 01:36 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
