Futaba 3PV (3+1 Channel Computer System)
New From Futaba
If you are tight on the budget yet, you don't want to compromise on the performance too much, Futaba 3PV will be your choice!
3PV include telemetry system, check the power voltage (with optional parts, you can check car's battery voltage as well), light weight design, easy to set up with interface.
Future include
Telemetry System
Steering EXP
Throttle EXP
Dual Rate
Sub Trim
Model Name
10 Model Select
A.B.S
4WS Mixing
2.4Ghz Build in Antenna
T-FHSS/S-FHSS/FHSS
Fail Safe
Receiver: R203GF
Weight: 8.0g
Please check us out on Facebook for weekly updates and Specials
Future include
Telemetry System
Steering EXP
Throttle EXP
Dual Rate
Sub Trim
Model Name
10 Model Select
A.B.S
4WS Mixing
T-FHSS/S-FHSS/FHSS
Fail Safe
Receiver: R203GF
Weight: 8.0g
