ヾ= ̄∇ ̄)ノ Hitec 44242 AA/AAA Charger X4 Advanced II
Ideal for Kyosho Mini-Z Racer or Tamiya Mini4WD Racer!!
HiTEC
Following has been updated from X4 Advanced:
Version II charging current has been increased to 2.6A
Charger case has been re-designed for heat dissipation (Slit design)
Capable of Bluetooth 4.0 Communication
Larger charge slot space for easy to attach / deattach the batteries.
New stand design for more stability.
USB Out put has been increased to 2.1A
You can even charge iPad etc!
Larger cooling Fan Design
Feature:
Can be charged Ni-CD & Ni-MH batteries x4 at the same time (any combination)
Blue Tooth capable
Can be connected to your smartphone via WiFi (iPhone & Android)
You can see graphical and full color screen from smartphone to monitor the charger
By using screen capture on your smartphone, you can save battery data
Battery performance indicator
Refresh & Brake-in mode to keep batteries to best condition
Delta peak can be set from your smartphone
DC input 12V
Charging current 0.2 - 2.6A
Discharge current 0.1 - 1.0A
Delta peak 5mV fixed (3 ~ 15mV)
End of discharge voltage: Fixed 0.9V (0.5V ~ 1.0V)
Battery tolerance : 200mAh ~ 2600mAh
Cycles of charge and discharge times: 1-12 times
Trickle charge current: 30mA
Protection circuit (temperature): Fixed 60deg (55 ~ 70 deg)
USB port output: 5V 2.1A There is the case that is not recognized by the equipment.
Body weight: 380g
Dimension: 154 x 104 x 50mm
HiTEC
Feature:
Blue Tooth capable
DC input 12V
Body weight: 380g
