Yokomo YZ-4
Yokomo YZ-4
Yokomo YZ-4
This product is available towards early -mid November 2015
We will start accepting PRE-ORDER soon! Place Pre-Order now and we will ship them off to you as soon as we receive your order. ETA may change without prior notice (due to manufacturing delay etc)
Yokomo “YZ” series of 4WD EP off-road buggies dominated the category for over a decade since its win at the
first EP Off-road World Championships in 1985. Winning 6 out of 7 World Championships (4WD) between 1985 and 1997,
the “YZ” is remembered as a formidable force, establishing unprecedented results.
Today, 30 years from the first World Champion title, the “YZ” is back!
Yokomo, in addition to on-road racing, will aim for the World Championship title in off-road racing as well.
Features
2 belt & 3 Gears * Gearbox Drive Train
Aluminium Hard Almight Main Chassis
Aluminium Top Shaft
Aluminium Front Suspension Mount (Skid 0/ 2.5 / 5deg can be selected)
Aluminium Front Brace
Aluminium Belt Tensioner Mount
Aluminium Battery Holder Nut
Aluminium Motor Mount
Graphite Steering Plate & Steering Block
Graphite Upper Deck
Graphite Battery Plate
3 Gear Front & Rear Gear Box (Graphite Reinfoced Resin)
Front Pulley (inc Clicker Type One Way)
Front Suspension Arm (Flat Type)
Rear Suspension Arm (High Traction Type)
Gear Diff (Metal Bevel Gear / Oil type)
Big Bore x33 Shock (Original Size X Ring)
All Round Series Shock Spring
Gap Forward New Body (inc Front Wing)
Gokuraku Off Road Wing : Narrow
Full Ball Bearing
C-Clip Universal Shaft
Aluminium 12mm Hex Hub
Steel Turnbuckle
Pinion Gear
Features
Aluminium Top Shaft
Graphite Upper Deck
Full Ball Bearing
Steel Turnbuckle
Pinion Gear
