New Yokomo B-Max2 MR Ver.3 Kit
New from Yokomo the B-Max2 MR Ver.3 Kit is now at Banzai Hobby!!!
B-MAX2 MR popular model change! Standard with the new aluminum main chassis, which is integrated to the front skid plate and show the driving characteristics of good response to the weapon the height of the stiffness. In response to artificial turf carpet road surface and it is growing these days in particular, it will acquire advantage in running a high-grip road surface that will become mainstream in the future. In addition, to prevent the blurring of the shock shaft by shock bottom cap is also changed, mounting the new plastic shaft guide, reduce air contamination of the cylinder, we extend the maintenance cycle and stability of shock absorption.
■ (can be selected mid-motor, rear of motor) new design aluminum one-piece main chassis
■ New design Aluminum Rear Suspension Mount (3,3.5,4 ° toe-selectable)
■ cab forward body type NEW
■ steel turn buckle
■ Double-pad slipper clutch
■ Aluminum front brace
■ New shock bottom cap
■ "C-clip" universal shaft
■ Full ball bearings
■ paradise off-road wing
■ pinion gear with wheel (without tires)
Please Join us at Facebook for Weekly Specials and Updates
Banzai Hobby Team
■ steel turn buckle
Banzai Hobby Team
