Tamiya Agrios 4x4 Monster Truck - TXT-2
New from Tamiya the Agrios 4x4 Monster Truck - TXT-2 is hitting our shop Soon
***Products will be shipped as soon as we receive them in stock (after 24th May)***
Specification
Scale : 1/10 scale
Construction type : assembly kit
Terrain use : multi-purpose
Drive-train : 4WD
Drive type : gearbox
Drive line : solid axle
Differential type : gear
Suspension : 4-link
Steering mechanism : direct servo
Shock damper : oil-filled damper
Shock damper material : plastic
Tire type : rubber
Tire tread : block-pattern
Body material : Polycarbonate
Chassis material : plastic
Electronic Speed Control (ESC) : NOT Included
LED Light buckets : no
LED lights : no
Motor : 540-brushless type
Bearings : shielded ball bearing
Adjustable camber : fixed
Adjustable toe angles : fixed
Adjustable ground clearance : fixed
Adjustable gear ratio : fixed
Adjustable wheelbase : fixed
Adjustable track width : fixed
Adjustable shock angle : fixed
Special feature 1 : Black resin-covered aluminum shaft side-frames are fitted with black aluminum panels.
Special feature 2 : Centrally-positioned gearbox with front and rear aluminum beams.
Special feature 3 : Resin upper frame serves as R/C unit cover and battery holder.
Special feature 4 : Two 540-motors included.
Special feature 5 : Front and rear axle cases contain 3-bevel differential gears and have a 2-level transmission.
Special feature 6 : 82mm width tires
Special feature 7 : Length: 510mm, Width: 344mm Height: 282mm
Requires A : 7.2 battery & charger
Requires B : 2-channel radio gear
Requires C : electronic speed control
Requires D : polycarbonate paint
Please come join us on Facebook for weekly updates and specials
Banzai Hobby Team
Specification
Scale : 1/10 scale
Drive-train : 4WD
Suspension : 4-link
Tire type : rubber
LED lights : no
Banzai Hobby Team
Tamiya Agrios 4x4 Monster Truck - TXT-2 is now in Stock.
Any Pre-Orders While be Shipped Shortly
Banzai Hobby Team
Banzai Hobby Team
