NEW Kyosho Racing Boat & Sports Plane
New from kyosho the Racing Boat & Sports Plane! now at Banzai Hobby
EP Jet Stream 888VE PIP Electric Powered Racing Boat RS
Get back into the action straight away with the unsinkable self-righting structure!
PIP kit provides thrilling speed and smooth turning performance!
The uniquely designed 2-stepped deep-V hull of the EP Jet Stream 888VE powers through waves and delivers incredible speed and turning ability. For pure unrelenting racing performance, this model offshore racer leaves all in its wake. Ballast compartments built into the sides of the precision engineered high-strength FRP hull structure facilitate the self-righting of the hull. In the event of capsize, water enters the ballast compartment and alters the weight balance to return the hull to its original posture. When the boat starts moving again, water is released automatically so the boat can continue running as it was prior to capsizing. The unsinkable design of the hull structure removes the fear of this precious boat ever being lost to the depths below. The pre-installed brushless outrunner motor generates huge torque but minimizes cavitation through the large high-thrust propeller and also provides wide options for the choice of other propellers. PIP specifications make it so easy for anyone to enjoy the high performance of this model. The completed hull with power train, servos and linkages is ready to use with your own transmitter, receiver and 3 or 4-cell Li-Po battery. This PIP kit even includes features such as trim tabs and adjustable brackets for tuning running posture that will please expert-level racers. The amazing performance of the EP Jet Stream 888VE can be enjoyed with ease so anyone can experience the exhilaration of power boat racing.
CALMATO ALPHA 40 Sports EP/GP BLUE
Ideal performer for low wing beginners to stunt training!
Designed for compatibility with both GP and EP flight!
When its time to graduate from a beginner trainer, the next step could be this stylish low wing sports plane. The option of either EP or GP in the CALMATO ALPHA 40 Sports allows you to choose your preferred power source. Both embody the definitive stability of the CALMATO series with optimal maneuverability allowing low wing airplane beginners to fly stunts like loops and rolls. In addition, this kit is factory assembled and expertly pre-covered in quality film with printed coloring and Kyosho’s comprehensive design and construction ensures no gluing is required. The main wing halves are joined with an aluminum pin and can be separated for compact and easy transport. Motor mount, engine mount, tires, spinner and linkage parts are all included. Only a few separate items are needed to get airborne so it’s easy to enjoy the sporty flight performance of this conveniently priced low wing airplane.
Please Join on Facebook for weekly Updates an Specials
Banzai Hobby Team
Banzai Hobby Team
