OVERDOSE: The coolest Aluminium Setting Board!!
OVERDOSE OD1147
High quality aluminium setting board released from OVERDOSE.
SIMPLY Coolest Setting Board in the world!!!!
All the logo and lines are done by full machining not by lazer marking! Pure quality...
Size:
420mm x 300mm x 5mm
You can use for alignment but also perfect for machine display.
These are only x300 available in this world and each setting board comes with serial number engraved!
We have absolutely limited number of these in stock.... So check out OVERDOSE OD1147 Aluminium Setting Board now and get in quick!!
Size:
420mm x 300mm x 5mm
