Kyosho AC/DC C-50W Balance Charger & Discharger
Kyosho AC/DC C-50W Balance Charger & Discharger Now at Banzai Hobby
<Specifications>
Input ●: DC11 ~ 18V ● Charge current or AC100 ~ 240V 50/60Hz: 0.1 ~ 5.0A (50W max) Discharge Current ●: 0.1 ~ 1.0A (5W max)
Battery Cells ●: LiPo / LiFe / Li of NiMH / NiCd 1 ~ 6 cells 1 to 15 cell lead acid peak Delta-● Ion 2 ~ 20V: ● Temperature Monitoring Temperature 5 ~ 20mV / cell adjustable ● safety features of the input voltage drops when the maximum charge capacity of the timer setting function ●
Users can also charge the electric engine to the user even if this is the definitive!
USB extension, but with the additional terminal, after installing the PC software will be released in the future deployment option allows you to manage data to chart the discharge.
● Display with backlight. Angle of 45 degrees for easy viewing.
Storage space and open the rear panel of the charger connected ●.
Charging Current ■: discharge current 0.1 ~ 5.0A ■: Input Current 0.1 ~ 1.0A ■: 11 ~ 18V ■ NiCd / NiVH: 1 ~ 15 cells ■ Li-ION/LiPo/Li-Fe: ■ Maximum charge 1-6 cell output (W): maximum output discharge 50W ■ (W): 5W
For more about the Charger please click on the link below
http://banzaihobby.com/index.php?mai...ducts_id=11608
Banzai Hobby Team
<Specifications>
Banzai Hobby Team
