Square SDC-104 TA05 Drift Conversion SP Kit Type-T: Blue
Taking Pre-Order Now!!
Popular TA05 Drift Conversion SP Kit is finally back from SQUARE!
Convert your TA05, TA05-IFS or TA05 Ver.2 to mean drift Machine!!
Features:
* Now using 2.0t Black Carbon Main Chassis for improved chassis Roll!!
* Chassis Roll amount now can be controlled with rear post. Easy and more setting options!!
* Motor position has been modified for perfect drifting balance (Front-Mid ship position) and akkerman is close to zero for more steering angle!!
* Aluminium Motor mount has been designed with easy maintenance in mind.
* You can equip with TA05-Ver.II Suspension Mount as well as Short Reverse Suspension System.
* Include 18, 20, 22, 30, 40T Pulley (for Ball Diff)
Set Include Following:
* 2.0mm Main Carbon Chassis
* 2mm Carbon Upper Deck
* Aluminium Motor Mount
* Aluminium Motor Mount Support
* Aluminium Spur Gear Holder
* Aluminium Steering Crank
* Aluminium Belt Tensioner
* Stainless Servo Rod
* Rear Belt 163T
* Front Belt 70T
* Resin Battery Holder
* Screws etc
* F630 Bearing
This can be used with Tamiya TA05, TA05-IFS and TA05-Ver2.0
For TA05Ver2.0: you require following products
A) Tamiya 51213
B) Tamiya 51209
C) Tamiya 51212
D) Tamiya 51242
E) Square STA-106
For TA05IFS-R, you require A,B,C parts from above.
For TA05-R you require C parts from above.
Limited quantity only. Place order now and save 15%!! So don't miss this opportunity.
http://banzaihobby.com/index.php?mai...ducts_id=10284
Features:
* Rear Belt 163T
* Front Belt 70T
* Screws etc
* F630 Bearing
A) Tamiya 51213
B) Tamiya 51209
C) Tamiya 51212
D) Tamiya 51242
E) Square STA-106
