Tire Guid
Tire Guid
Hi i need help with choosing new tyres ive just upgraded my Tamiya df-02 with a Caste Creation brushless system, New Pinions and now i would like to get thicker tyres i did read one other post on this but i just simply didnt get it so i do apologise if their have been several of these posts. Im pretty sure the stock tire diametre is 86mm i was thinking of getting much thicker tires that would fit my Df-02 does anyone have any good suggestions. Thank you!
Heck, you should be careful with a brushless system in that. They're not really made to handle that sort of power. I wouldn't run it on anything besides loose dirt or u may strip your gears!
Your car is an old design. Old Tamiya cars are great fun for playing and really tough. The standard wheel sizes for today are different tho.
My favourite tyres for playing in the dirt are Proline Calibers. You'll need new generic rims (not a tamiya part) with the correct size hex (12mm i think). You'll need to take it to your LHS (local hobby shop)
You need standard size 4wd buggy rims to be able to use the different sorts of buggy tyres out there. Go to a hobbyshop that sells cars for racing (losi, associated, xray, yokomo, mugen etc..). Not a big chain shop like "SIK" that sells cheap chinese stuff. Those shops will not help u.
Good Luck!
Good Luck!
Hi Jay,
If by thicker tires you mean taller I wouldn't do that, the front would rub the bumper. If you mean wider tires you would have a simular issue. Check out what your local hobby shop has as far as some descent rubber, tamiya does do 2.2 rims that will fit good rubber, you will just have to track some down.
There is a possibility of getting some wide offset low profile stadium truck wheels and tires to fit but that would be about it.
