Team Orion Vortex R10 Pro
Hi Guys,
I am having a few issues with my ESC.
Software is up to date, parameters are set as they should be for blinky.
As soon as I plug in the sensor wire the motor turns then stops, I have tried 3 sensor wires.
I have tried 2 different motors, the same thing happens. The motor will work fine without sensor lead, however as soon I connect the sensor it all stops.
Any assistance would be grateful.
Mate you have got a issue with the sensor control circuit in the esc. Its failed. The only way to run it now is without the wire…. No timing or anything thats just it. So its a throw away job unless you run it like it is…. Cause unless you send it back to orion no one else can fix it.
Good luck with your decision mate
