Supernova Competition charger?
#46
hiya guys!!
anyway i will be getting my supernova competition in the next couple of days so i cant wait!!!!!
anyway what i want to know is what is the ideal cutoff temp recommended for the gp3300 cells???
if anyone knows please either pm me or just reply on the thread
cheers
cheers
#48
GP3300 CELLS
I have only just acquired this charger and I am after assistance with a setup for GP3300 cells. Please post on this forum site, so that others can use the settings.
Thankyou.
Calvin.
Thankyou.
Calvin.
#49
can someone tell me where on the net i can buy this charger?
#52
Originally Posted by kermit
Check out www.radiomodels.com.au
#53
your in sydney right? ring up auswide windsor(or penrith) and they will order one in for you,
www.auswidehobbies.com.au
21/64 Drummond Street, South Windsor
(02) 45773166
(02) 45773166
#54
(02) 45773166
(02) 45773166
#55
The charger has trumps on the LRP... the LRP is still a good unit if you dont need fancy features or more discharge grunt. I like model memory, dunno if the LRP has this.... For the cost of a supernova comp, I doubt there's anything better (for the money).. who knows
For my GP3300 matched packs:
6A charge (stock racing) 5A charge (mod racing)
20A discharge setting
3mv/Cell delta peak
50C cut off temp
<Linear> charge mode
<Re-Peak> for peaking before a race (change Delta peak to 1mv/Cell when repeaking)
I use the same settings for the IB3600's, but with a 5mv/peak, coz they just arent as good as GP's.
For my KAN1050 pack's, 1.5A charge, 3A discharge, 6mv/Cell delta
For my AA Stick pack (8 AA's in transmitter), 1A, 6mv/Cell delta
For my lathe, motor run in screen, 3.0V
For running in motors, 2V, coupla mins
3mv/Cell delta peak
50C cut off temp
#56
3mv/Cell delta peak
50C cut off temp
3mv/Cell delta peak
50C cut off temp
What do you have your peak delay set at? 1-10 minutes.
#57
GP3300 INFO
Thanks James. I will give that a go.
Cheers
Calvin.
Cheers
Calvin.
#58
hiya all
just got my charger today
anyway i have 1 prob at the moment
has anyone had problems with motor run in feature????
it just could be that my main battery is so flat
that it just comes up with motor connection error!!!!
anyway ill charge it up and see if that works
please let me know if anyone else has had this problem or not
ok
cheers
ok
cheers
#59
peak delay (nicd/nimh only):
The charger does not start the peak detection at the beginning of charge to prevent the charger from accidentally stopping too early.
- the adjustable range is 1 to 10 minutes.
so basically, it wont peak detect until after this time variable has passed.
mine is set to 4 mins, but i might change it to something higher for some of my more stubborn batteries that like to think they are charged when they definately arent..
motor run in feature.. mine said something about a connection error last time i used my lathe. i just unplugged and rechecked the connection to the lathe, and it worked fine...
#60
hi does this charger do Lead Acid (PB) 12v Gell Cells?
