Go Back   R/C Tech Forums > International Forums > Australian Racing
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-07-2005, 04:48 AM   #1
Monaro_Racing's Avatar
Default NimH Discharging?
I have some new batteries on the way, they are GP 3300 NimH ladder packs and i intend to use a discharge / equaliser tray.
now i am guessing that the novak smart tray is the bees knees but is there anything some what cheaper that will do a good job until i can fork out for the novak?
and with NimH what is the best way to store them between rounds (2 weeks) discharged, charged, left as is after a race?
Monaro_Racing is offline   Reply With Quote
Old 04-08-2005, 05:58 AM   #2
Jack2's Avatar
Default batteries
well from what I can make out the Novak isn't the bees knees because even tho it is very accurate with detecting the cells cut off it doesn't hold it there as soon as it reaches the cut off point, it lets the cell build its voltage back up so they are all getting different amounts of time to regenerate energy. It would be the bee’s knees if it held the cells at the cut off until the last cell reached the cut off point.
Personally I like the Integy zero 6s zero equalizer from eBay or some online stores in HK. It takes the cells down to zero and holds them there. It costs way less than the Novak (around $27 US) and if you buy a couple of them they are stackable which is cool if you don’t always have heaps of space. Easy to use and great quality. Another great discharger is the one form harrisrc.com . 20 amp equalizers have become a lot more popular than the Novak trays. As you will find on the EP on road threads
I have had the best results, leaving them fully charged while in storage, discharging them at 30 amps about 5 days before you race, and then start equalizing them for the entire 5 days. Put them on when you go to bed and take them off during the day or vice versa, and continue to keep rotating them, keep them on the equalizer for 24 hours straight before you charge and charge them as soon as you get it off the equalizer. You probably don’t have to go to all that trouble but it does seem to make a difference. I'm getting better run time and they are holding there punch for longer in the race. But I am not sure about the cells life yet but so far they are holding up very well.
I know there are zillions of different battery charging/discharging /cycling methods and I don’t want to start a battery war, but this just how I do it. Not saying it’s the right way, just my way
I'd recomend getting on the harrisrc thread. ozoner(scott harris) will help you out I am sure)
Mugen MTX-4R
Jack2 is offline   Reply With Quote
Old 04-08-2005, 06:16 AM   #3
Jack2's Avatar
Default ZERO 6S
Also note that Surikarn used the (Integy/much-more) zero 6amp trays at the 2005 TITC race in febuary.
you can see them stacked up on the right of the picture
Mugen MTX-4R
Old 04-08-2005, 07:21 AM   #4
nam_tc3's Avatar
Default Re: batteries
Jack,
Your advice is not entirely true and misleading.
nam_tc3 is offline   Reply With Quote
Old 04-08-2005, 08:33 AM   #5
VenomWorldOrder's Avatar
Default Re: Re: batteries
Originally posted by nam_tc3
Jack,
your comment is not entirely syntactically correct just being a d**k joke brother!
VenomWorldOrder is offline   Reply With Quote
Old 04-08-2005, 02:29 PM   #6
Jack2's Avatar
Jack,
Well lets hear the truth .........
I didn't say it was the right way, I said its MY WAY.
Mugen MTX-4R
Old 04-08-2005, 05:04 PM   #7
nam_tc3's Avatar
Default Re: Re: Re: batteries
"Your comment is misleading, and not entirely true"
That should pass the VWO compiler now with no errors....
Old 04-08-2005, 05:32 PM   #8
nam_tc3's Avatar
There's no need for the tray to hold the voltage there and let the cells regenerate at the same time. Each cell will regenerate to a certain level and stay there, regardless of how much time you give them to regenerate. Usually takes about 5 mins for the pack to settle. Even if you cut-off the cells at the same time, each cell will regenerate at different rates anyways.
Those trays aren't exactly 'equalisers', they're more of a conditioner. The equalising is only a consequence of leaving the cells on there for days, and having each cell reach 'zero volts'.
Deadshorting non-believers should not have to use these trays to equalise their packs.
Equalising the pack on a smart tray will only take 5-10mins by bringing them all to 0.9V......then you can bring them down further if you choose to.
Yes.... you will need more than 1 tray. Which will end up costing the same or more than a smart tray.
Btw, battery care techniques are constantly changing, especially with all the new cells coming out, at least with a smart tray you'll know that it can take care of whatever to come.
Jack, i wasnt criticising your battery care techniques. Only the above mentioned points.
Cheers...
Old 04-08-2005, 06:47 PM   #9
Jack2's Avatar
yeah thats ok. I haven't had the time or money to try every battery conditioning/maintenance method out there but i know that a lot of poeople replaced the smart trays for integy INDI Zero-Thirty discharge boards and the Apex trays which are zero-twenty trays. as I said from what I can make out its not quite the bees knees because I still dont like the idea of them getting to the cut off point and be let to regenerate at different times but i dont suppose it makes a whole lot of difference.
Either way falking out for something thats going to give you better performance and save you money in the long run isn't really that bad.
Mugen MTX-4R
Old 04-08-2005, 10:05 PM   #10
Thanks for all the Info fellas.
I am going to "Aim" to get a smart tray but it will inevitably come down to budget so the Integey and apex options sound good.
Old 04-11-2005, 04:53 AM   #11
Stonzy's Avatar
Send a message via ICQ to Stonzy Send a message via Yahoo to Stonzy
I have 3 smart trays and what i normally do is when all the lights go out i equalize them again then wait till the lights go out and then do it a 3rd time and then charge the pack immediately.
That way normally on the 3rd restart on the novak the lights all go out roughly the same time or close to it.....
Go down to 0.9v
Seems to work fine with me. Then need to have around 43 mins to peak them before the race. It's all about timing on a race day to get the maximum volts Best to peak the batteries just before the race starts Best i've done is around 90 seconds before race starts
But it also helps when you have multiple chargers and discharges so you can have a few packs on the go
Stonzy is offline   Reply With Quote
Old 04-23-2005, 06:21 AM   #12
BrainTeased's Avatar
Default Re: Re: Re: Re: batteries
Hi Nam
so do you have any tips for storage with racers who race once every fortnight and use the novak smart trays.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 04-24-2005, 03:21 AM   #13
Default Re: Re: Re: Re: Re: batteries
Originally posted by BrainTeased
Hi Nam
depends what batteries you are using. the old 3300's are a bit more robust and can handle different care techniques.
the new 3600's and i think, also the 3800's are more "fragile" in how they should be maintained. (ie discharge/charge rates and storage style, minimum voltage in each cell required etc).
according to the supplier i got my cells from, feral (cannon on this forum) with the ib's you should never discharge below 0.9 per cell, and have a mV peak of 3. also it is recommended to charge at 6 amps if memory serves me right. never dead short them.
the old gp3300's you can dead short and charge rates are a little bit more open. if you race every week or two weeks just store the pack at 0.9 per cell and charge either at the track (this requires alot of time) or the night before.
if not using for more than 2 weeks i tend to fully charge them, then store them. then i discharge and charge again when i am close to the race date
Old 04-24-2005, 03:56 AM   #14
Default Re: Re: Re: Re: Re: Re: batteries
Thanks Tom just the answer i was looking for!
does anyone know what methods for storage of IB3600 cells? for people who only use the packs once every 2 weeks.
Old 04-24-2005, 04:38 AM   #15
Default Re: Re: Re: Re: Re: Re: Re: batteries
dead shorting is only recommended for stock. mod guys don't do this at my track.
some stock guys should shed some light on DS'ing and if it is useful.
ib3800's care instructions should be on the smc site i think?
Forum Jump
NiMH discharging ? Bulldawg RC Electric Off-Road 4 01-14-2008 06:26 AM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 10:58 PM
Discharging and Discharging Question jeffbhhs Electric On-Road 5 12-14-2006 05:34 PM
discharging Nimh batteries? j240z Rookie Zone 8 04-29-2004 11:33 AM
discharging batteries (NiMH) warlord385 Electric On-Road 6 02-01-2003 09:52 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
