GM V4 - no go..
GM V4 - no go..
here's another doosy - got a used GM V4 but cant get any throttle response.., led comes on power up,, steering servo works fine but no throttle response at all.
i tried it on two other cars, with different batteries and receivers, same thing... cant see a reset or program button on it..
is it buggered or am i missing something?
thanks guys!
thanks guys!
im not sure but i think every time u turn the esc on you need to re set the throttle features i know one of my friends had one and i remember they had to do something like that, hope this helps
Dave
Dave
thanks guys... just cant see a reset button on this one !
Its a very good Esc, the only problem is that program feature.
Sometimes you have to wait a little before you program it.
Like Rod said, turn on the transmitter and keep it in neutral until you turn on the Esc and wait a few seconds. Just make sure the first thing you do is put full throttle, otherwise forward will be reverse on the transmitter.
Had a bad experience once when the battery short circuited in the race and i had to drive with the control backwards for the rest of the race.
Originally posted by 414m2
Yeah there is no reset button. Basically to reset it you have to turn it off then turn it on.
Originally posted by murfy
that would have been a bitch to drive. i don't understand if the esc takes all of this setting up before each race why buy it????
It wasn't mine. It's a good esc, lots of punch, very small (size of a Lrp Q2), it doesn't blow up and its good for all drivers.
Much as I love GM Speedys (the SX9 and SX12 are exceptional pieces of kit), if I had to program my speedy every time I turned it on, I would not own it for very long. That's just plain stupid.
-Scott
-Scott
-Scott
-Scott
But when you think about it most people turn on their cars and rev it then put it down. Basically you are doing the same thing, its not like a normal setup where you press the button and look at the lights, its just turn it on and pull the throttle.
It's a good esc considering its size, there arn't many bottom line esc's that are the same size as expensive top of the line ones, so for the beginner its a good choice.
I own 2 Yokomo's with V4 speedo's.For a racer on a budget
they are great.Their small size makes them perfect for the tight
squeeze that Yokomo's demand.The reset requirement is just
part of our normal pre race prep.
-Scott
-Scott
This has been my experience with v4s and I've been running them for about 2 years
i like the v4.. but if u dnt turn it on and wait and pull the trigger right in then right out etc etc it wont runn properly ihve had it "auto" set so that it wasnt throttling up properly etc and in the pressure to get ur car on teh grid for a race easy to stuff up.. but there a good esc small and get goot current limits for the price
well, the tx is on, then the 4 is switched on, i wait for several seconds, do the throttle thing but nothing happens... after a few minutes one side of the esc get pretty hot so i turn it off.. looks like a dodgey one... btw, does it matter if the battery and motor positive wire solders touch each other on the esc?... i thought not but just checking...
thanks again..
thanks again..
in the GMv4 (not r) the battery + and motor + are the same thing.. most brake ESCs are like that but if the battery + and other stuff touches then ur in troubly.. generally if it gets warm withoug 5 mins of hard running then its stuffed.. if you are any good with eletronics open it up the V4 is easy to diagnose and fix.. ive fixed plent of V4rs because the reverse fet goes in them if you drop them once or twice (abit of a design flaw)
Hey Merc-Blue is it possible to mod the V4r to convert it to a V4?
ie dissabling reverse but keeping full brake.
