19turn racing in australia
#47
True that!
If 19T does become a class does this mean Stock is out?
#48
I believe 19T should be run to ROAR rules. I know this means fixed timing, but in Australia it seems that we follow what they do, albeit a bit behind.
Here is the link to the ROAR Rules:
http://www.roarracing.com/rules/pdfs/2004rules.pdf
Note that adjustable timing motors are only used for oval racing in the States, something that we don't do here.
#49
which motor??
I'm interested in the 19t class ..
my question is which is good competitive 19t motor and where can i source em from ...
cheers
cheers
#50
most over seas hobby shopes stock them and i know cmc in syndey stock some.
i run the epic outlaw 19t (its a bullet) but if they do introduce the rules about the fixed timing don't get it. i have also heard that the new team orion 19t is good to. i don't know its name i'm sure someone else will though.
#51
thanx for that murfy ..
i think i'll get a motor that has fixed timing ... just in case there the rule is introduced ..
if not ... guess it's a good reason to further improve my skills and try not to rely on speed ...
on the team orion motor .. does anybody have the link?? i could not find it ..
thanx
thanx
#53
If you guys end up running fixed timing motors.....
I will have stock of EA Tuned Trinity Chameleon 2 motors in early January if anyone's chasing a motor. C2's have fixed 24 degree timing, and are machine wound.
Manufacturer details : http://www.teamtrinity.com/motors/19turn.asp
Tuning details : http://eamotorsports.360k.com/ea_home.html
PreOrdering details : http://www.harrisrc.com/shop.htm
We (well, the club...) are running this class (19 turn fixed timing) at Brendale in Brisbane from next year. Should be fantastic I think. The current plan is to restrict motors to those on the BRCA approved list - check the England Park thread for details and a link to that.
Personally I don't overly care if it's fixed timing and approved motors or not, athough if I had to make a choice it would probably be for fixed timing - as someone said, to make it a cheap(er) class. In my humble opinion we need to make racing cheaper if we can.
Whatever happens, I just want all of Australia to run the same rules...
The decision depends whether you want 19t to be a "fast stock" class, or a "slow mod" class I guess. At least that's the way I think of it.
-Scott
-Scott
#54
wat do u guys think of the Reedy Spec 19t Quad-Mag Motor??
#56
Ive got one to its a good motor,fast and smooth
#57
I think that having a 19T class is a good move, it gives people a chance to step up to a faster class without the expense of having to go to Mod where how much you spend determines how competitive you are. We starting a 19T class Feb next year in Adelaide when we get our new indoor carpet track up and running, and I am really looking forward to it. At this stage it looks like we will be running as per the ROAR rules which states fixed timing. Hopefully it will be some good racing.
#59
Originally posted by cannon
If you don't go for fixed timing it will go down the track of the old Group 20 class - timing from hell...new brushes and retrues every race. This killed G20 racing
#60
not that much difference between fixed and variable timing motors any way.
I found that having adjustable timing I could actually turn it back a couple of degrees to smooth it out with out loosing top end that we tried to achieve
