help with my Losi 810
could somone please tell me a good glow plug/charger and reciever battery that would be compatible with my Losi 810 and that would last a full race day with a full charge.
thanks Rhys
thanks Rhys
help?
Any glow starter will easily last a full day at the track, as for a receiver pack look towards lipo, im running a venom 7.4v 2100mah (through a regulator back to 6v), it could possibly last a full day but to give it a bump up inbetween races wouldnt be a bad idea, the last thing you want is a run away
would a: ''Team EPIC Enduro Glo-Ignitor with 4600mAh Battery'' do the job?
and for a reciever battery how about a: ProTek R/C Li-Poly Losi 8ight Receiver Battery Pack (7.4V/2000mAh)''?
That gear sounds like the go, just be sure to run a regulator with lipo receiver packs if you are still running the spektrum radio gear so you dont fry it,
will it work with the radio that comes with the 810? i have no idea what a regulator is aha?
and would an 1800mah glow igniter last a full day of racing on a full charge?
a regulator is like a voltage stepdown. in your case, if you're buying the 7.4v lipo battery, a regulator is needed to bring the voltage down from a fully charged 8.4v battery to an acceptable voltage of most servos and receivers which is at 6v.
http://www.amainhobbies.com/product_...tage-Regulator
if you're not used to lipo battery, it can be very dangerous. you might be better off buying another nimh receiver pack.
as far as the glow ignitor is concerned, my old 1600 mah lasted a whole day. so you might be fine there.
