i need recommendations for a airbrush
ay people i currently have a 2hp compressor with a regulated valve outlet. i want to get a airbrush kit so i can start doing my own paintschemes.
i want a kit that has all the stuff neccessary, and minimal need to upgrade.
can you suggest a type of airbrush, and what brand, and also how much they cost and were from.
Wombat, i'm curious to know what you use, and how you modified it to accept the fascolour glitter?
You've almost answered your own question. Get a Faskolor F1 airbrush. Not even sure if they're available here (mine came from OS) but it's the way to go. They are suitable for Faskolor paint (Normal airbrushes dont like it) and they can also spray other lexan paint equally well.
I only spray Pactra Polycarb but the Faskolor airbrush is brilliant.
I'm a professional Illustrator anyway and I used to use Badger airbushes exclusively, but now for bodies I only use the Faskolor one.
p.s. I hate Faskolor paint though.....
My two came from Tower Hobbies. I havent seen them here at all, although that doesnt mean that they aren't available....
If your after a complete unit with 3 different needle sizes, hose and bottles get a paasche vl set. Good airbrush for the what you want.
As i use a airbrush for 6-7hrs a day Iwata (HP-C or HP-BCS will do you). These are what the fascolor airbrush is coppied from but the quality is just 1st class and cant be matched(wolrd leader in airbrushes).
Dixie Art in the US is the place to go they have all the major brands and are cheap.
Coxy.
the "plus hp-c" or the "hi line hp-c"
HP-BC only: $169.95
HP-BC w/ 9 color Com-Art Set: $174.95
i basicly want the best one, so i have no need to upgrade in the future.
http://www.dixieart.com/High_Perform...irbrushes.html
http://www.dixieart.com/IwataHB_C_BC1_BC2.html
Both the HP-BC and HP-C range can shot fine lines but not suitable for large areas of single colour or glitter.The HP-C Hi-Line has a MAC valve that would just get you in trouble so go with the PLUS if you decide to go this way.
For me i would say go the HP-C PLUS but also get a Passche VL set for glitter, if you want to shot glitter and fine lines with the same airbrush get the HP-BCS eclipse slightly larger nozzle but can still give great detail.
I have in my own collection a HP-C (optioned up), HP-BCS eclipse, Passche VL set plus more. I use them all but for rc bodies I use the HP-C the most cause it can do everything you want except glitter (Passche VL set with no.5 needle is the best for this)
for finer detail i use an airbrush, for filling in areas in a single colour i use a "touch up" type spray gun, gravity feed type, this is good for large areas in a single colour, that i have mixed up, by using a gravity feed type there is no wastage compared to a pot type. you can get these from any trade paint store, depending on where your from upwards of $100.
