Do speedies "just" blow up?
Yesterday I smoked one of my LRP V7.1's in my B4. Nothing apparent shorted out, wasn't plugged in backwards, I hadn't touched the car since it was raced at Maitland Cup 3 weeks previously, put a battery in, turned it on, gave it some throttle and once on the track it just shutdown with lots of smoke, melted the case - so basically it is stuffed.
Like I said I checked it all out and couldnt see anything obvious that would blow up a speedy, the chassis is not graphite either, so my question is can they just blow up from an internal fault. The speedy is about 4 years old and has ran faultlessly all its life
Cheers
Molky
Cheers
Molky
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Originally posted by MrRolla
The same thing happend to my Mtroniks digisprint though, took it out to practice it was going great for 5 mins then POOF up in smoke it went..
(btw Mtronics Sonic 4 sale..make an offer)
I know in the old tekin manuals ,they had a warning about dirt build up in the cases causing shorting on the circuit board, moisture and elements of metals in the soil.
I clean all my radio out at least once a month, receiver, speedy, and servo.
You would be amazed how much dirt gets in side.
It must work , I still have a Tekin 410k in my 4wd, and never had a problem.
Good luck.
Good luck.
Good luck.
Good luck.
ie. do you use chemicals/brush etc.
Good luck.
Good luck.
If so, then its just about certain to be dodgy electronics..
I'm not bashing LRP, I've been using them since I started racing, I had a V6 blow up when a friend wired it up wrong, but other than that they've been great so far, I just really want to know what caused this one to go bang. The speedy in my 4wd is going on 5 years old and still goes strong
Speedies are subject to the second law of thermodynamics and therefore will go out spectacularly, it happens to them all. Bloody entropy gets in to everything.
Do they blow?
Just the blue ones have problems
its funny for me because i have had a novak for about 3yrs now and it was about 2yrs old when i bought it. i have never had to clean it out or re-wire it or anything like that.
and i have never experenced an esc blow up only one of my friends manual speedies.
so i would like to know what does make speedies just go 'poof' and blow up. if any one can give me and most likly others out their a simple explanation why?????
I think the smaller they are the more chance of problems.
