Spektrum DX3R Setting Problem
Who know Spektrum DX3R Frame rate setting? Manual say digital servo must be used 5.5ms.
My problem is: if i use 1 digital servo and 1 analog servo, how i setting my frame rate? If i set to 5.5ms, the analog servo sound Z......Z......Z.......
but it write must be used 5.5ms.
Hi M8 to me it reads that only digital servos can use the 5.5 setting ,only because because anology servo can not use a frame rate of 5.5,but all should be able to use 11,16.5 settings,with means running the digital servo at 11,16.5 to tell you the truth I stopped racing for 10 years when only anology servos where around and now I use the Digital servos and between 5.5 and the older frame rate I really can not tell the difference
it states that only digi... servos to use 5.5
but will be fine with 11 which is what i run mine at with a 9551
