Best Onroad Stock Combo???
Hey,
I am just starting out in Onroad Touring EP Class and was wondering what the best 17.5 Motor & ESC combo most people are using.
Cheers
Cheers
LRP Stock Spec or Tekin RS Esc or KO BMC or Team Wave RB Series
and the Duo series of motors are winners hands down.
Fantom, Express Motors etc are all duo motors that are re labeled so anything thats duo based and your set
Darren used a RB30. Both RB30's and 50's perform the same but the RB50 has a fan and ability to run Mod. The RB30 has been used to win races in 10.5. If you run 10.5 in hot conditions you will need a fan on a RB30 or you could play it safe with RB50. For 17.5 the RB30 is all you need.
The RB30 retails in OZ for about AU$150! Thats good value.
Where can u get 17.5 duos in Sydney?
Paul, I picked an RB30 up today - no, not a Nissan 3 litre six,but a Team Wave speedy.
Any chance you can give me some suggestions for setting it up for stock and super stock ?
Both motors are Duo 1s.
Thanks,
Michael.
Thanks,
Michael.
Neutral Brake(Drag Brake) 1 = 0% (this is personal)
Brake Force 4 = 100% Then dial down a bit with radio
Turbo 1 = ON (Very important)
Timeshift 3
Drive Profile 5 (I plan to go to 7 next time out)
Brake profile 7
Temp Cut 5 = Off
Lipo cut 7 = Off
Motor Type 1 = Brushless forward only
10.5 rollout 38mm
17.5 rollout 50mm
Please be aware that those rollouts are high and you should try a 2 minute run then temp your motor then another 2 minutes and so on. On a high traction night you will put more load on your motor and need to gear down 1 or 2mm and if you crash a lot that also puts more load on your motor every time you pull away from a stop. Not wanting to be rude but thats what your signature says I do hope you supported our good friends at WHRC and not that person parallel importing them?
as no combo has been mentioned here
you cant go past Tekin
tekin rs and tekin redline 17.5
and with its currant software it is very competitive never mind it next step
which is soon to be released
were the teamwave is updatable but they have decided to release a new speedy instead... the RB30-S
Dont see his sig saying anything about crashing You have got the wrong person
With the current crop of ESC's you simply have to decide which way you want to go.
With a company that actually provides updates to the firmware or with a company that says it will have upgrades and doesn't and then releases a new ESC when apparently the older ESC can take the upgrade.
For the high quality and best support from the factory you cant go past Tekin
Here is what I run. I use this at windsor but it was good at Whalan too.
Timeshift 3
Brake profile 7
Temp Cut 5 = Off
Lipo cut 7 = Off
10.5 rollout 38mm
17.5 rollout 50mm
Timeshift 3
Brake profile 7
Temp Cut 5 = Off
Lipo cut 7 = Off
10.5 rollout 38mm
17.5 rollout 50mm
One more Q: What timing on the motor ? I have the Duo 1 motors.
I may own two Xrays,but that doesn't mean I enjoy crashing- that's more Tailend Racer's thing! Check HIS sig.....
Yes , I picked the esc and card up from WHRC yesterday ( Where I buy 80-90 % of my gear). spoke to the Splitman about it a little.
So I can now compare this to my SPX........ It's substantially cheaper , so this will be interesting !! Thanks again for your help, it looks like i'm ALLOWED out this friday too.
Fleety.....
I am currently running a tekin rs with a speed passion v3 17.5t and it is awesome. Perhaps not quite as fast as the duo 2 but it is mighty close! I tend to find the speed passion holds less temp than the duo2 and cools much quicker. It is also a little more consistent throughout a run.
Thanks Paul
Fleety.....
Fleety.....
Sorry about that whole crash thing. Who look stupid now! But it is a good point that some people don't realize. Crashing makes your motor run a little hotter.
