Foam tire ?
#16
Nah i didnt bother with the spray at the end because I saw that the oil from the spray was leaking out onto the chassis plate and outdrives. I used a very thin layer of tamiya molybdenum and it works great
Hey I was just looking at some speedmind foams. Do you know if their 40 shore rating is the same as the grp ones? I have used speedmind before and theyre dishes are bulletproof and dont flex at all
#17
Originally posted by VenomWorldOrder
please there are quick EC mod racers on this forum don't embarrass me!
#18
Originally posted by tabmow69
Really? Who?
Really? Who?
just wait 'till i get the new EP.....just you wait.
#19
#20
Trader Rating: 22 (100%+)
tabmow69,
do you know where we might be able to get Kawahara foams from overseas now that Stu wont be importing them anymore
#21
fastolfart thank you
#22
Originally posted by Mad Mackem
I cut a new pair to 58mm for the Summer Nats. You will only get 2 or 3 meetings out of them at that diameter.
#23
I found most of the GRP foams are readily available overseas and here as well. However, If I did manage to get some Zacs, would I go for their 40R compunds or get the 37R? Also it seems the speedminds are wierd in that their 26mm rims are for front and rear and have 37,40,42 ratings...whats good for speedmind?
#25
umm...everyone i'm lucky there is generally only 10 mod racers at EC. i always make the A's even BK is quicker than me now.
#26
the Zac 40 rears seem to have the same grip as ellegi 40 rears (laptimes are the same), but dont seem to wear as much. i normally run 2degrees camber on the front to get ellegis to wear flat, but i only need to run 1degree to get the zacs to wear flat.
would you believe kawahara (the mob who makes the zac foams) is italian. the name sounds japanese
#27
Can someone tell me were I can buy Ellegi
#28
if Prospect is not to far, Hobbytown has them for $20 a pair. this is the cheapest in Australia as far as i know.
if you want to get some from overseas try
http://shopping.rcmodel.com.hk/
they are very cheap even including postage from Hong Kong.
#29
Thank you muchlee
