Advise re; SP GTV1.1 esc
Hi Guys,
got a SP GTV1.1 esc I'd like to try with a brushed motor..
The Program card says it will do brushed motors
Problem is, I don't have an instruction sheet, so if anyone has one they could email it to me at [email protected],
Or can advise me as to which wire goes where plus some tips on how to adjust via the program card would be most appreciated
Many thanks in advance...
BTW if you need another GT I have a 1.0 and a 1.1 lying around... Though someone is using the 1.1 at the moment. I'll have to ask if they want it.
Don't suppose you know if the programming boxes are compatible between v1.1 and v2?
If you have a 2.0 you will LOVE running it with spec brushless like 17.5 and 10.5. Gear down a few teeth and you will have more speed than your old speedy with much more power.
