Go Back   R/C Tech Forums > International Forums > Australian Racing
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-02-2007, 07:49 AM   #1
acko's Avatar
Default 3pm ? wot is throttle ATL
just wondering what the throttle ATL is? is it like a throttle curve setting? any input would be great. im am looking for a good middle of the range radio and the 3pm looks good but i would like a programable thottle curve as well
thanks
TEAM TRASH TALK TOURING
losi mini baja/ sidewinder brushless on 3s li-po
losi xxxt mf2/ speed passion brushless 4.5 + li-po
pti goliath crawler... (always being modified)
hpi baja 5b ss 29.5 cc setting up 4 1/4 scale speedway
acko is offline   Reply With Quote
Old 10-02-2007, 09:17 AM   #2
d4_racer's Avatar
Send a message via MSN to d4_racer
throttle ATL is short for Adjustable Throttle Limiter and it works by adjusting the total travel available to the braking side of the servo of the throttle servo.
so its not for electric, but i may be wrong.
who here uses a custom throttle curve for racing?
\____
==\_\___===___ | *HPI Baja SS kit;*
==(@)\_______\(o) +UNDER CONSTRUCTION+
out of racing, but a proud marshall, lol
d4_racer is offline   Reply With Quote
Old 10-02-2007, 09:32 AM   #3
Turbine_au's Avatar
I use a little negative exponential on the throttle to help tame the car down on power out of slow corners. I have a 3pm and haven't touched the ATL.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 10-02-2007, 05:12 PM   #4
Swanny's Avatar
ATL is an electronic adjustment of how much the throttle moves when the trigger is pushed forward ie. it is in effect a dual rate setting that only works on the brake side of the throttle. On the 3PM it is linked to one of the adjuster switches so it can be adjusted on the fly, like steering dual rates.
What you're looking for is called throttle exponential, which the 3PM has. It is not programmable but you'll probably find that it will be enough for you. On the 3PM both brake and throttle exponential can be adjusted independently. You'd have to go to a 3PK to get programmable throttle curves.
I use a 3PM myself and recommend it to you as a good mid range radio with all the features you need. I run electric touring car and 2WD buggy and it's more than enough without being overly complicated. I've had mine for 2 1/2 years and have no plans to replace it. With everybody else going to spread spectrum, my decision to stick with a crystal radio is paying off as I never have to change frequencies.
XRay T2'009 - Futaba radio and servo & LRP 10.5 Brushless power
RRCSA Secretary & Newsletter Editor
Swanny is offline   Reply With Quote
Old 10-02-2007, 09:39 PM   #5
Turbine_au's Avatar
I've got the 3PM-fasst and strangely enough, I don't have to worry about frequencies either. Love the radio, does everything I need and more.
Old 10-03-2007, 12:11 AM   #6
Swanny's Avatar
It can be used for electrics. When running a one way on a 4WD touring car it can be used to turn down the brakes so you don't get the handbrake effect so strongly. With a spool I leave it at 100%.
Old 10-03-2007, 03:33 AM   #7
dubbsy's Avatar
I too use a 3pks radio and I enjoy the benefits of throttle curve especially when launching the kicker at the back of rovs house but i spose you already know this . Maybe i'd just like to gloat a bit more and thanks for the oppurtunity ACCO.
Trash talk touring West africa division
1 x brown goat named ethyl
1 x white goat named Marmaduke
3 x chooks with pooey bottoms
1 x mudhut with grass roof . containing 15 famly members
2 x blue left foot thongs
1 x dose of malaria/typhoid/yellow fever
dubbsy is offline   Reply With Quote
Old 10-03-2007, 04:56 AM   #8
acko's Avatar
It's a 3PM thread you silly boy, not 3pkfasst,
(SSHHHHQQURRRRISSSTsquelch2.4ghz00,............... .....are you reciving, over).
but Thanks 4 your input.
Old 10-03-2007, 05:10 AM   #9
Clippy's Avatar
Trader Rating: 45 (100%+)
Yeh acko, as swanny said 3PM has throttle exponential (curvature) Typed up a longer more detailed post but then thought better of it. It'll just attract the know all flamers anyway You can have a bash with my 3PM if you think it's what ya want man. I just found that using throttle exp. didn't teach me to stop mashing the throttle in 540 toasting days. I ended up switching it back to 0 (linear) and practised being smoother with the trigger
Clippy is offline   Reply With Quote
Old 10-03-2007, 10:07 PM   #10
acko's Avatar
yeah wot i want is a more responsive feel to my throttle so i acctualy have to use less throttle for the same power. ie..... full throttle is peeked just after half way of the travel of the trigger if its possible. i feel like i have to move the trigger heaps when negosiating the s, s for instance. just driver preferance i guess.
i started this thread as i was just browsing transmitters and id never seen ATL before and just wondered what it was.
ive still gotta look at kevs ko mars as i was to busy with my car again last week between races to have a good look as im running my updated chassis now.
THANKYOU TO ALL THAT REPLIED
Old 10-04-2007, 03:42 AM   #11
Hey Acko
I suggest you take a look at the Nomadio React. It has all of the things mentioned above and more, prob for the same price if not less.
Just thought it might be worth you taking a look is all.
Cheers
Matt G.
mattmask is offline   Reply With Quote
Old 10-04-2007, 04:00 AM   #12
Turbine_au's Avatar
I think you'll find the Nomadio is more expensive than a 3PM.
Forum Jump
T-maxx throttle pinky2252s Monster Trucks 1 12-30-2007 08:29 AM
all or nothing throttle birdy Radio and Electronics 0 12-27-2007 11:23 AM
Throttle help duffman1977 Nitro Off-Road 7 10-08-2007 01:57 PM
THROTTLE CONTROL gonzo416 Electric On-Road 18 02-06-2007 08:39 AM
Throttle Servo?? Hoggy Nitro On-Road 4 08-02-2005 11:13 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
