bearings
#16
thanks goodez that helped alot actually yeah i could see that small C clip but i didnt want to take it off incase i bent it and couldnt get it back on but maybe i will have a look in there some day
#17
Originally posted by Ooj
I think ill have to have a look at the prices for the tamiay blue rubber sealed ones now. The smallparts site quoted me $110 for a full bearing upgrade (excluding the steering bearings and diff thrust bearing). the following bearings are needed. Are they wierd sizes? Anyone know approximately where to get these and how much or do all tamiya bearings cost $3-4 each as jono said?
4* 15mm outer, 10mm inner, 4mm high
2* 12mm outer, 8mm inner, 3.5mm high
1* 12mm outer, 6mm inner, 4mm high
8* 11mm outer, 5mm inner, 4mm high
You can also buy sealed bearings from other places, try Boca Bearings etc etc if you don't mind the importing.
#18
Metro Hobbies in Melbourne should stock most of the common sizes, but i am not sure on this.
website: http://www.metrohobby.com.au
Ph: 98901144
Ph: 98901144
